Question about Xerox 8860dn Phaser All-In-One Thermal Printer
Xerox phaser 8860 duplex not working - Xerox 8860dn Phaser All-In-One Thermal Printer
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
SOURCE: PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Posted on Oct 09, 2009
SOURCE: My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Posted on Jan 06, 2010
  • 2072 Answers
SOURCE: xerox phaser 8860 light streak in cyan color field
On your panel, scroll to troubleshooting, then to something that states something like adjust image quality or repair image quality.
You are looking for a procedure called simply "remove light stripes, and also remove smears and streaks. Run those and they should clean your jets and resolve our problem.
Posted on Jan 19, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
Error 08,035.42:7417 after power loss. on 8650 phazer
my xerox printer phaser 8860 is stop printing. message show, 08,035.42: 138484. Is this fixable
Apr 05, 2011 | Xerox Phaser 8560DN Laser Printer
My Xerox 8860 scans a blank page before each document.
One possible solution.
Check to see if you are set to duplex copying as default, this would cause it to print a blank reverse page of any single sided document.
Jan 05, 2011 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
Nov 09, 2009 | Xerox Phaser 5500/DN Laser Printer
Xerox phaser 6120 not duplex printing since it's wireless network
You have to go to printer properties and look for "optional functions" or something to that effect, and check the option "duplexing unit" or similar.
By default the computer does not know, that your printer has duplex capabilities.
Oct 27, 2009 | Xerox Phaser 8400 Laser Printer
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox phaser 8860
This unit has a common situation that requires parts and 2-3 hours of labor. This error points to a bad process motor 127K53240
These generally go bad with 2 camshafts 020K14800 and 008K02160
Whit
Item, Inc.
Jul 10, 2009 | Xerox Phaser 8560DN Printer
8860 print error 07,010.43;92622
print out comes after restarting the phaser 8860 printer and stops after sometime
Jul 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8860 error code 34,015.48:66749
Hi
Cyan Ink Level Sense Fault (34,015.48)
You must have a minimum of something like 3 ink blocks in each cartridge so it looks like the CYAN is running low. Double check that you have a least 3 in each one and the error should go after a reboot. Please use the link below for any further problems or let me know.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8860),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8860,varset=prodName:Phaser%208860
Mar 20, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8860dn  Phaser All-In-One Thermal Printer Logo
329 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
