Question about Dryers
Gas dryer not heating
Fault code 06 and an older 90 code futher down listing.Maytag, gas, dryer, MDG5500AWW , new 12/04Heating not uniform takes forever to dry???Cleaned unit completely, no obstruction to the hood outside, checked all sensors, fuse, igniter, coils, all show closed status. gas odor present during cycle, (not lighting?), not good!, something is not allowing the igniter to light in cycle only initially???
  • Anonymous Jan 10, 2009
    my dryer is not heating I dont know what todo.
  • 640 Answers
It seems you have a lot of knowledge,,,i ran the schemtic,,and the only thing i could see that could be,, bad thermistor,,or the microprocessor control went bad..keep me posted onthejob
Posted on Jan 10, 2009
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer not producing heat
Might be a fuse due to a clogged lint buildup or possibly a bad blower wheel itself. On a gas dryer the fuse only kills the gas assembly. The motor will still work and the dryer will still operate with a blown fuse. If it heats a little bit and quits it could very well be the solenoids.
SLOPEFACE DRYER MANUAL
Aug 30, 2012 | Maytag Dryers
Maytag dryer (model MDG5500AWW) will not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
WORKING BUT NO HEAT MDG5500AWW
remove the exhaust tube from the rear of the dryer and try again for heat. If it works the tubing needs to be cleaned out thoroughly., Also upon starting you should her a click which is the ignitor firing up the burner. If not heard within one minute the ignitor is at fault
Dec 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
heatman101
Dec 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
97 people viewed this question
Top Dryers Experts
