I have a Ruud ugda 075c-er .. the pilot light is on and the blower activates however the pilot light does not engage the flame.
The pilot light is on and the thermostat will turn on the blower but the flame will not turn on
relaga58
  • 158 Answers
SOURCE: There is no power to the unit even when plugged in.
check circuit breaker if on check fuse inside unit if tripping or busting again it has major problem
Posted on May 13, 2009
  • 89 Answers
SOURCE: Ruud ugda-10ec-er wiring diagram
Go to www.mediafire.com/?lzqjzjbonod I hope this comes to you as a link you can click on, there you can download a wiring diagram. I just did.
Posted on Nov 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: rudd model #UGDA-075C-ER furnance shuts off before
Make sure that the air filter is clean and there are no restrictions in the duct system ie. carpet over register, dog lays on vent etc... If that looks OK, check your thermostat to see if it is still calling (sending a signal) to the furnace by inspecting the circuit board. I think this model of furnace will blink rapidly if there is a call for heat. You can confirm what your furnace does by looking at the board when there is a starting of a heat cycle. Keep in mind that you will need to look thru the small viewing window and not remove the door panel that has the door safety switch. The door switch de=energizes the system. The board will also blink a certain number of times if it experiences an error. You can find the diagnostic chart on the wiring diagram pasted on one of the door panels. It may give you a starting point where to look if you have an error code blinking.
Posted on Feb 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I HAVE A RUUD SILHOUETTE GAS FURNANCE. The pilot
Short answer, yes. However you could have another problem. Replace the thermocouple that keeps the pilot lit. You can get a universal one at any good hardware or farm store. Make sure the new thermocouple is well into the pilot flame. If the blower knocks out the pilot flame again, I would be suspecting cross contamination from a crack in the heat exchanger. As the exchanger heats up, it may be causing a small crack to open and allows the blower to extinguish the flame. It may also be causing a leak of Carbon Monoxide into the heated room air. I would get it checked out very quickly.
Posted on Mar 07, 2010
  • 127 Answers
SOURCE: ruud model ugda-150a-ar getting pilot to light
the ignition system may have a broken igniter or plugged gas orifice if the ignitor is working.
Posted on Oct 25, 2011
Where is the flame sensor location on a Rheem RGDA-075C-ER Gas Furnace made in 1991
Flame sensors are always located directly in the flame, as it leaves the burner/in shot. The flame comes directly in contact with the flame rod/sensor. It's usually near the last orifice on the manifold, farthest away from the gas valve.
Mar 18, 2017 | Heating & Cooling
Why rheem rgda-075c-er when trying to cool comes on goes off comes on untill reaching room temp set on
either compressor going off on safety, thermosta issue or loose 24 volt connections.
Jun 25, 2014 | Ruud UBHC Air Conditioner
Ruud model ugda-150a-ar getting pilot to light
Oct 02, 2011 | Ruud UBHC Air Conditioner
Problems with a gas Ruud ugda-075c-er
Sounds like the black box that you are talking about is a auto relite kit, usuall is a after market part. Check and make sure the gas is turned on, on some of the older relight kits, they will spark all the time.
On the gas valve is there a pilot position? If so turn it to pilot position and push down on the knob, with the system calling for heat,,,so that you are hearing the buzz, if it does not light, push down on the knob and light the pilot the old fashion way,, with a long match, if the pilot lights, hold the knob down for a minute or so, then let go and turn it back to the "on" position.
I hope this helps.
Paul
Mar 13, 2010 | Heating & Cooling
I HAVE A RUUD SILHOUETTE GAS FURNANCE. The pilot light keeps blowing out. When I light the pilot flame it seems to work perfectly at ignition. As the Manual instructs, I hold down the ignition switch for...
Mar 07, 2010 | Ruud UBHC Air Conditioner
Rudd model #UGDA-075C-ER furnance shuts off before reaching desired temp setting set it on 73 it will cut off at 66 etc.
Feb 25, 2010 | Ruud UBHC Air Conditioner
Oct 26, 2009 | Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
