Question about Measuring Tools & Sensors
What size torx driver for paslode im250 fan motor screw
jj505
  • 195 Answers
SOURCE: paslode im250 fan comes on, fuel cell good ,fires
Please make sure use by date is current on bottom of fuel cell. If no date buy new fuel cells with useby date. Fuel has lost its ignition flash point. please reply.
Posted on Mar 16, 2009
jj505
  • 195 Answers
SOURCE: paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Posted on Mar 19, 2009
jmillward330
  • 6 Answers
SOURCE: paslode im250 type 2 wont fire
sounds like its losing presure when fireing it could be the next oring if its the rubber one replace if its the metal one take them out and clean the grove they sit in and make sure u space them, meaning the gap in the rings should be set 180 deg apart. this should work if u r getting a spark when the gun is apart. the cable could be making a bad contact at the spark unit and when u r checking this make sure its getting a good contact at the spark plug as well hope this helps u.
Posted on Aug 16, 2009
Testimonial: "thanks, this was helpful. later found out that the ignition wires were chaved behind the trigger, but got new problem now the firing pin is sticking."
SOURCE: Hi how to change the motor in paslode IM250
There is a small torx bolt in the fan, heat the bolt up to losen it, then remove fan.
Now remove spark plug lead and unplug the wires to the butterfly board.
Then remove the circlip that is holding the outer rubber attached to the fan.
Hope this is some help. any problems contact your nearest paslode repair agent.(check on the paslode web site for your local repair agent)
Good luck.!
Posted on Jan 15, 2010
  • 25 Answers
SOURCE: how do you clean the cylinder of an paslode im250?
The tool has to be complety torn down to clean out cylinder area and to check for wear on the orings inside of cylinder. Not a quick or easy job.
Posted on Feb 11, 2010
How to open up paslode
Use this link to parts schematic http://www.paslode.co/uploadedFiles/Cordless_16ga_straight_finish_Parts_Diagram_Schematics.pdf
Remove filter cover (1) and filter (2) remove 4 x cap screws (3) then remove top cover (5) disconnect spark plug lead and fan supply led then rotate head anticlockwise and lift it off, slide out front extrusion (56) remove 2 x screws (68) at bottom front of gun (1 each side) remove 4 x screws (80) from left hand housing cover and 1 x screw (59) from left side of handle bracket (83) Note: Do not remove right hand screw from bracket (83) you will now be able to lift the right hand housing and remove it from the groove in the nail channel, the barrel, combustion chamber and nail channel assembly can now be swung up and out of the right hand housing
Jul 01, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
How do i take of the fan from a paslode im350+ gun ?
1) Remove the 4 bolts at the head, remove filter cap
2) Remove 2 bolts at nose holding the front assembly to the handle
3) Carefully pull the nose out and down to separate the cylinder and handle.
4) Remove fan blade - there is a very small torx screw on the fan blade
5) Remove the 3 screws holding the fan motor in and pull the motor straight out
Inside the cylinder head where the fan motor sits is a plastic spacer - if your fan kit does not come with a new one don't forget to take it out and reinstall it in the new head.
Jun 17, 2014 | BreatheAudio Paslode Impulse Cf325...
Were do u get a paslode driver blade
Locate the part number online by searching for the tool's model number "parts list" Once you have that information you can visit you local Fastenal and they can order it for you. Paslode will not sell directly to the public on spare parts. They will point you in the direction of a service center. I only know of two: Fastenal and Fasteners Inc.
Nov 09, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250 fan running slow. light goes solid green when pushed to shoot, or pull trigger like it wants to fire. But fan runs slow and it wont fire! hot wired fan and it's fine . Changed the fan wire...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Jan 03, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250, green light flashing but no fan working and not firing
heatman101
Dec 17, 2010 | Craftsman Nailer Kit, Palm Air Driver
NO FAN WHEN TRIGGER IS PULLED
heatman101
'll
Sep 24, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
How do you clean the cylinder of an paslode im250?
Jan 29, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hi how to change the motor in paslode IM250 i took the gun apart but i can not remove the motor
Good luck.!
Sep 15, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250 fan comes on, fuel cell good ,fires sporadically
Mar 14, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250 f-16 only able to drive 2 nails .
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
