Question about Electrolux Dryers
I have an EDI 97170 clothes dryer and it is giving me error code E32
2 Suggested Answers
  • 174 Answers
SOURCE: AEG Lavamat washer dryer, machine
Yes you need to change the cold water valve you dont mention the model so it will either be a 2 coil or 3 coil water valve. one of the valves responsible for the tumble drying condensing is faulty.
Posted on Jul 30, 2010
What is E32 on A3100IS Cannon Camera
This is an Error message look on the Canon website for the list of error codes.
Apr 13, 2016 | Canon Cameras
Error code E32
Your users manual lists some trouble codes. E32 is not one of them. The manual states for all other codes switch off the machine and if it returns call customer services the number is in your manual they will require your model & serial number. They prefer to do this first before dispatching service personnel to cover the warranty.
Sep 16, 2015 | Washing Machines
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
My electrolux dishwasher is throwing an E32 error
Hello Heber Allred - Are you certain that the error code is E32? This manufacturer does not have an E32 error code for any dishwasher. They do have E02 or E12. Is the hum noise more like a grinding noise? If so, then I recommend contacting a professional to move forward accurately. The unit may be experiencing an issue with a faulty drain motor.
Dec 11, 2012 | Dishwashers
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Dryers
Error e32 sx210
Getting Canon error codes usually means a trip to the Canon service center for a fix. There's a discussion in the DPreview forum regarding the same problem.
Apparently an E32 error code results in the camera powering off in exactly 60 seconds in the playback mode. It not necessarily affects just the G11 but other PowerShot models too.
Generally E-series error codes mean either a hardware or firmware issue that cannot be rectified by the end user.
Hope this helps
Positive feedback ALWAYS welcome :)
Mar 03, 2011 | Canon Cameras
New Install Went Fine Until E32 Message After Install Cycle - what the heck is an E32 error?
E32 indicates a problem with the pressure sensor. The service manual says to check the wiring (replace if bad), replace the sensor, if problems persist, replace the main circuit board.
There's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
May 16, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Dryer f51 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Nov 04, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
