Question about Canon Pixma MP270 All-in-One InkJet Printer
Canon Pix MP270 : Start keeps flashing plus triangle below and despite document being in the queue, the PC and printer are not connecting.Help
As above plus a little box keeps saying to switch off printer and re-start. Noticeable too that the green bar goes a short distance but alas, no printing of doc
SOURCE: unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Posted on Apr 02, 2008
SOURCE: Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
SOURCE: My Canon Pixus 50i printer
I have something to ask you, Can you tell me where I can get drivers for the printer Pixus 50i.
Posted on Apr 10, 2009
SOURCE: canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Posted on Apr 24, 2009
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
Tip
Canon pixma mp270 Drivers for Windows and MAC OS
Here Iwill show you where to find drivers and manuals for the Canon Pixma Mp270 photo all in one printer.
Drivers for this printer are available for Windows98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions,windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.3/10.4/10.5/10.6
A full on screen manual, quick start guide andother instructions are also available.
To download these drivers and or documentation foryour printer please visit
THIS PAGE
Note that the picture says MP190 but the actual page linked will be for Mp270
1. Clickon Drivers & downloads
2. Select your OS ( Operating system, windows, macetc )
3. All available drivers, documents etc will beavailable below.
For some of the documents a PDF reader may berequired to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdfreader(s)
Thank you for reading and I hope your printer isup and running again.
-Ekse
on Mar 11, 2010 | Office Equipment & Supplies
E05 problem
Canon Pixma MP270 error E05
Apr 22, 2014 | Canon Pixma MP270 All-in-One InkJet...
Error message E-1-6 lights keep flashing
Hi Stacey,
Go To Below official Canon Printer Video For Your problem and Solve your problem
Still having Problem Then follow Us For Canon Printer Support
Feb 24, 2014 | Canon MP270 All-In-One InkJet Printer
Message printer offline
Hi
How about disconnecting it completely from PC and from power.
Wait a few minutes and then connect again.
Clear any paper jams and print queues.
Mar 04, 2012 | Canon MP270 All-In-One InkJet Printer
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
CAN NOT DELETE A DOCUMENT THAT IS IN THE QUEUE, THEREFORE, NOTHING ELSE WILL PRINT. THE DOCUMENT SAYS IT IS DELETING, BUT DOES NOTHING. i POWERED IT OFF, THEN UNPLUGGED IT FOR A WHILE AND IT IS STILL...
First method.
Regards,
Ron
Jul 02, 2011 | HP Photosmart Premium C309A All-In-One...
Low ink light flashing even with new cartrige in it
The same thing happened on my MP270 printer and I had to reset the cartridge status by pressing and holding "STOP" button (circle with triangle inside) for 5 seconds, until the flashing indicator light stopped blinking.
For further details read the manuals here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=71896
Mar 05, 2011 | HP DeskJet 5550 InkJet Printer
Need to install cannon mp270 with no disc urgently to print of tickets for consert that starts in hour please help
Sure you can download the Drivers for the Cannon MP270 from the below link:
http://support-au.canon.com.au/contents/AU/EN/0100203601.html
Mar 02, 2011 | Canon Office Equipment & Supplies
How do i scan a document to file using a Canon MP270 Printer?
Even if I try to scan from the Canon and not from the computer I cannot scan as pdf only as an jpg image
Can someone give me a hint to solve this?
Jun 24, 2010 | Canon Pixma MP270 All-in-One InkJet...
Canon Pixma MP270 All-in-One InkJet Printer Logo
old marine
old marine
