Question about Onkyo TX-NR717 7.2-Ch THX Certified Network A/V Receiver
Can a power amplifier be connected to Onkyo TX-NR717 - if yes any power amp models recommended
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
SOURCE: Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Posted on Apr 17, 2009
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
Can a Onkyo tx sr604 receiver be used as a pre amp?
Yes. You can use the Line Out, or Pre-Amp output into another receiver or amplifier. The receiver or amplifier you use as the amp, will need to have a volume control, as the line output coming from the TX SR604 cannot be varied.
If you have any further questions, please visit my website at audioserviceclinic.com and contact me there.
Thank you.
Jun 06, 2014 | Onkyo Audio Players & Recorders
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can...
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
Jun 10, 2010 | Onkyo TX-SR604 Receiver
Onkyo tx-SR605 - how do I use as a processor and
IF and only if, your receiver has connections labeled as "pre-out" can it be connected to an external amplifier.
If it does, then you connect from the left and right channels from the receiver, to the left and right channel on the amplifier.
Jan 02, 2010 | Onkyo TX-SR605 Receiver
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
HDMI Problem help me
With onkyo amps with hdmi up scaleing you have to tell the amp to let the signal through.To do this first press the setup button and you will see input assign,press enter,monitor out appers,press enter you will see hdmi out NO,flick enter button to the right this will change to yes,you should have a picture now.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Dec 31, 2006 | Onkyo TX-V940 Receiver
Onkyo TX-NR717 7.2-Ch THX Certified Network A/V Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
