Question about Dishwashers
On my hotpoint aquarius dwf30 the tablet dispenser will not stay closed, you hear it popping open as soon as you shut door and if you don take it out and re try puting it in dispenser it just gets flushed away with first rinse, is there anything I can do or can you buy replacement dispensers?
  • 1003 Answers
SOURCE: Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Posted on Jan 18, 2008
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
stefano-61
  • 69 Answers
SOURCE: The detergent dispenser sliding door will not stay closed
it is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Posted on Jan 08, 2009
  • 3247 Answers
SOURCE: Bosch (SHU6802UC) dishwasher detergent dispenser
It is possible the latch, spring or the actuator needs replacement or adjustment.
The parts are shown in this diagram. Items 8,9,10 etc.
You will have to open the door inside cover to access these.
Posted on Nov 20, 2010
BElectric
  • 1140 Answers
SOURCE: I have a bosch dishwasher model number
Hello Andrew,
I'm more than happy to give step-by-step instructions for replacing the detergent dispenser, however it's not cheap (about £50) and it probably doesn't need to be replaced. Some of the smaller components for the dispenser are available separately, so it would be better to work out what's wrong with it, before replacing any parts - or the entire unit.
The dispenser may be receiving an erroneous signal from the controller to open when the dishwasher is in delay start mode. To check this, switch the power off, insert a tablet in the dispenser, and slide the door closed. Make sure it clicks shut fully (push on the arrow on the door)and then wait for a few minutes to see whether it opens.
If the tablet will stay in the dispenser with the power off, there is nothing wrong with the dispenser. If it opens with the power off, you may just need a new dispenser door or a spring. Please try this simple test, then get back to me for further assistance.
Regards,
BElectric
Posted on Apr 12, 2011
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Aquarius dwf30 dishwasher lights are on but wont work
SEE the w .diagram
2) test the switch door, it is open or defective will not close the starting relais for turn the main motor.
God bless you
May 09, 2012 | Dishwashers
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
I have a bosch dishwasher model number SGS0902GB/05. I use tablets instead of detergent. I put the tablet in the Dispenser and close the lid, noproblem. I then set the programme and shut the door, I...
Hello Andrew,
Regards,
BElectric
Apr 12, 2011 | Bosch Dishwashers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i have a dwf30 for some reason all the items are coming out with lots of grease marks on them the tablet pops out ok as you can hear it but everything seems as if its not been rinsed out i thought it...
is there any strange rumbling or moaning coming from the drum ??? if so the oil and greace may be from the back bearing due to the bearing oil seal becoming faulty allowing water through to the bearings
Feb 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Saying to close door and we already have
When you shut the door , do it very firmly until you can hear the latch click, if it still will not start, then you could have a faulty door lock or a communication problem between boards.
Plz rate my solution.Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
Hotpoint aquarius dwf30 dishwasher
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
