Question about Toshiba Satellite P755-s5320
Toshiba satellite p755-s5320 motherboard
Looking for a replacement mother board
raevenzero
  • 53 Answers
SOURCE: How do i remove the keyboard
Usually you can remove the panel right above the keyboard, this will allow you to access the keyboard screws. The keyboard should swing up allowing you to unplug and remove it.
Posted on Nov 26, 2007
SOURCE: Toshiba Satellite A75-S226 Notebook PC can i get mother board for this ?
Well I did a google search on A75 series and found that this is a manufacturing issue and that Toshiba should call back the laptop or provide a replacement free of cost.
What happens is that there are two cooling fan at the bottom of the laptop and the works as vacum cleaner..it blocks the heat vent and overheat the system and shuts down...at some point it does affect the powersupply and the hardware guy only has to say that we need to replace the motherboard, so if the motherboard if messed up coz of the way laptop is designed then Toshiba should replace the part.
Posted on Feb 27, 2008
SOURCE: toshiba satellite pro m70 power problem
windows xp not instltion
Posted on Mar 22, 2008
  • 6 Answers
SOURCE: mother board for toshiba satellite
try ordering a new one from the Toshiba website,or try buying on ebay.
Posted on May 18, 2008
AZBen
  • 193 Answers
SOURCE: i have a toshiba satellite p305d-s8828 laptop and
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
Posted on Oct 07, 2009
The battery run down without no use and when you boot it, it will shut down by it self, and is booting slowly.
If this is a new laptop, you need to migrate your data off it and get it replaced. Something is draining your battery, or the battery is bad. Keep the power cable plugged in and save what you need. Contact your vendor customer support for a replacement.
Mar 17, 2015 | Toshiba Satellite P755-s5320
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
My laptop fell off he bed and the power comes on but the screen is blank. i tried plugging to an external screen but no luck. i just want to urgently get a few documents before it goes in for repairs......
if you tried to plug another monitor and do not work, is signal that control video is faulty.
You must go to some repair shop computer for to fix it. or you mus dissasemble the l.top and order the parts.see the video attached
God bless you
Oct 01, 2013 | Toshiba Satellite P755-s5320
Toshiba drivers WINDOWS 7 64 BIT
You can use a wired Ethernet connection to connect to the router.
This requires a different set of drivers to Wi-Fi.
Sep 05, 2013 | Toshiba Satellite P755-s5320
My Toshiba satellite p7S5- S5320 just got in January2012, well i let a friend get on my computer and when they got off my back lights on keyboard stop working, can some one please help me to get it ba
First, don't even think about using the recovery disk for this. Talk about overkill.. Would you really wipe out your entire system just for a little light?
Ask your friend what they did Then just undo it.
Don't let anyone use your laptop unsupervised. Or, create a guest account with limited restrictions and let them se that.
Don't know what type of system you have, since you didn't mention it, but check the documentation that came with the laptop, or look in the control panel for the keyboard settings, or the MobleMe software.
Hope this helps. Please rate this response.
Randy
Aug 31, 2012 | Toshiba Satellite P755-s5320
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Motherboard for Satellite P30-149 P4 538/XP
If you want to buy this replacement Mother Board, contact Toshiba. If you need help replacing it, let us know and we can direct you from there. If you are having a problem with and upgrade or a component on this Mother Board, please give us more detailed information on what your problem is.
Thanks, and Good luck.
Feb 22, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba Satellite P755-s5320 Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
