Question about KitchenAid Kitchen Ranges
Kitchenaid stove KGRI801 door is locked and panel is dead
  • 2336 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Kitchenaid superba Stove Door
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
Posted on May 03, 2009
SOURCE: Oven went dead in self clean mode and the door
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Posted on Mar 30, 2010
drifterK
  • 4924 Answers
SOURCE: My wife used the self
If you can locate the thermostat ..from the rear access ..and short it ..(jumper it) while powered..the door will open ..after that you need to see what caused this..and replace the part ..
Posted on Oct 03, 2010
  • 17 Answers
SOURCE: I used the self cleaning
I will need the model#. It is probabaly the thermostat on the back of the oven.
Posted on Oct 20, 2010
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Kitchen aid electric stove does not go on
check the door lock switches on the door lock they get bent out of sdhape real easy
Jun 29, 2009 | KitchenAid KERC607 Electric Kitchen Range
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
UNLOCK STOVE DOOR
no code for unlockin door, were you self cleaning unit prior to door locking? if so themal fuse problably tripped off for percieved saftey reasons( thought it got too hot), you might be able to jimmy door open witha wire hanger bent a 90 degree angle maybe 2 in long slide it between console and door latch should release to the left. good luck fishin!!!
Feb 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
KGRA806PSS00
We had the same problem as well. everything locked up and the display board went dead. It turned out to be the thermostat in the back. Once that was replaced everything worked ok. . The serviceman told us to pull the oven out from the wall when self cleaning. It is because the heat disapation and air circulation from the oven is very poor when running at maximum temperatures and this burns out components. First check the termostat, which is a $20.00 item.
Sep 08, 2007 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
