Question about Whirlpool Refrigerators
Need manual for Whirlpool fridge/freezer FRSS36AF20/2A
4 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
toolkits
  • 1099 Answers
SOURCE: WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Posted on Jul 30, 2010
Sea Breeze
  • 4654 Answers
SOURCE: get a whirlpool manual
Gary this has been almost as difficult to get answers as was my frustrations of being married to my first wife! I have never understood why it is so hard for the people of the UK to get answers to Appliance problems without having to pay for help to have repair. I do know that American and United Kingdom brands made by Whirlpool are most times different by Model Number, Part Number and Electrical Voltage. What I need to know is if the Ice maker is making a terrible noise and if you can disconnect and pull it out and then lets see what is happening. I have a PDF of the common brands FRWW2VAF20/0; FRUU2VAF20/0; FRBB36AF20/2; FRUU36AF20/2; FRSS36AF20/2; FRSB36AF20/2; FTSB36AF20/3; FFII36AF20/3; FRSS36AF25/3 But I will send you to the Website click Here=> Whirlpool Refrigerator FRBB36AF20/2 This is a diagnostic and defrost control system drawing of instructions. Now can you send me photos of the ice maker and the location of the noise you are hearing? Unless you can do a few things I will need to compare our two Countries Brand differences. John Tripp/AKA Sea Breeze http://appliance911seabreeze.com/ here is my e-mail=> appl.....(at)yahoo.com then fill out the capsha to reveal my address. I will send you a Whirlpool American Service Manual. Communication is the only way I see getting this repaired. Thanks, JT
Posted on Nov 19, 2011
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
I need an owner manual for the whirlpool refrigerator with the model number ET14JKXDW10. Inside fridge leaking water
Water inside fridge usually due to blocked drain tube, clear with drinking straw and check door seal and clean condenser
May 09, 2012 | Whirlpool Refrigerators
Do you have instruction manuals? I have a 6WRI24NG and it seems to be dripping water from under the freezer bit into the fridge, and everything in the fridge are is freezing.
The problem seems to be with the condenser. the freezer is leaking because of the breakage of temperature between freezer and the fridge. I will update you soon.
I have not found an online manual yet for free. But we could find the free manual from the company's website.
Jun 27, 2011 | Whirlpool Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Looking for a manual for a Whirlpool fridge freezer, model no 6WMV35
You can find and download a manual at servicematters.com . This is a Whirlpool site , but you will need your complete model number .
Oct 25, 2009 | Whirlpool Refrigerators
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Whirlpool ARC7470AL FRIDGE FREEZER
ok you need to replace your thermostat its out of calibration or sticking
Feb 11, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
226 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
