Question about Whirlpool Ovens
Whirlpool SF317PEAW0 oven won't ignite
Stovetop ignites, oven doesn't
rylee_smith
  • 8619 Answers
SOURCE: the oven will not ignite
Hi
Thanks for using FixYa. The air holes on the side of the burner that faces the center of the stove may be clogged or holes near the oven are clogged which are leading to uncompleted combustion of the fuel and thus leading to the foul smell. This helps the pilot or spark igniter to light the gas. Try cleaning the holes with a toothpick.
Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in too, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Igniter is made up of a crystal which gets damaged or distorted physically and wont work fine until replaced. This may lead to incomplete combustion of fuel and is a safety hazard.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 26, 2009
SOURCE: Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Posted on Jan 02, 2010
meztang
  • 112 Answers
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
heatman101
  • 43501 Answers
SOURCE: jennair gas oven. lower burner won't light, i.e.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 18, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
2 problems! Sometimes the lower oven doesn't start. U can hear the motor humming kinda but when I spin the blower wheel it'll start up and ignite. I've tested the capacitor and good. Any idea?...
I am not sure how you tested the capacitor but your issue is a classic one for a bad capacitor. The second problem is not very clear. With that being said, the wire could be grounding somewhere other than the ignitor. Please clarify a little more and I will help you work thru this.
Jun 22, 2017 | Blodgett DFG200 Stainless Steel Gas Double...
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
Oven Problems Replacing the Igniter
heatman101
Jul 13, 2011 | Ovens
The lock is displayed on the clock and dont no how to get it of
If you're talking about the oven and stovetop being locked so you can't cook, on mine you usually hold the oven or stovetop light button for about five to seven seconds and it clicks off. I have a Kenmore, but I know sometimes they're similar. Also, if the power go outs, it automatially goes into lock mode.
Jun 26, 2011 | Whirlpool Ovens
The oven is not heating up, its not even turning on. there's no gas or fire. the stovetop is working. what can be the problem.
Since you didn't include the model number, I cannot check for you to find what type igniter the oven uses but if neither broiler nor oven will turn on, it is probably one that uses an electrical spark that isn't happening. If the broiler works, it is a 'surface' igniter and the one servicing the oven has failed. There is no gas because the flow is blocked if no ignition is occurring. This is an important safety feature otherwise the oven would just fill with unburnt gas and finally explode.
Jun 17, 2011 | Hotpoint Ovens
Bad ignitor? I have a Maytag oven CRG9800BAE displaying F7. No oven heat. Stovetop burners work fine. Got the code cleared, clock is working fine. Is this a bad ignitor? If so, could you confirm the...
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
May 12, 2011 | Maytag Ovens
Amana oven, AGR5835QDW igniter in oven is shot. Stovetop lights, broiler lights. How do I access the oven igniter to replace it?
Oven ProblemsReplacing the Igniter
heatman101
Apr 01, 2011 | Amana Ovens
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Open Questions:
Ovens Logo
43 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
