Question about Motorola Mag One BPR40 Two Way Radio
How to program a mag one motorola bpr 40 portable two way radio
Noggin
  • 944 Answers
SOURCE: PROGRAMMING
here is a link to the manual for your radio (english http://myweb.accessus.net/~090/bearcatting.html#motoman They do not give out the information of how to program it, only authorised technicians are permitted to do so. Here is the link to motorola customer support in Puerto Rico https://www.motorola.com/pr/feedback.jsp They should be able to tell you where you can get your radio programmed, and what programming is permitted in PR. Hope this helps :)
Posted on Mar 21, 2007
eradiostore
  • 1654 Answers
SOURCE: what version of software (CPS) is needed to
RVN4196 CPS (Motorola proprietary software subscription) which also does the Radius CP125.
Posted on Sep 30, 2009
SOURCE: need a free download of an operating manual fo the
I need a service manual of motorola T 5417 A ,. I hope you can help me . Thanks a lot
Posted on Nov 07, 2009
eradiostore
  • 1654 Answers
SOURCE: We purchasedn 3 bpr 40
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Posted on Sep 14, 2011
eradiostore
  • 1654 Answers
SOURCE: How do I connect Mag
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Posted on Sep 19, 2011
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How do I set to scan BPR 40
This is only done through use of the programming software and cable. Your radio would need to be reprogrammed.
Feb 07, 2014 | Motorola HT1000, MTS2000, MTX8000/9000...
How do you program the programmable buttons on a bpr 40
you will need programming cable and programming software
Oct 07, 2012 | Motorola Mag One BPR40 Two Way Radio
What do the buttons on the bpr 40 do?
Both buttons have a short and a long press function. The button right below the PTT button is typically programmed to short press Monitor, long press Sticky Monitor. The bottom button comes from the factory on scan/nuisance channel delete. The buttons can be custom programmed when the dealer is programming the radio, so these are just a general guess based on the factory default setting. Other options include repeater talkaround, high/low power, volume set, and maybe tight loose squelch.
Best regards.
My bpr 40 all time have a green light on in a scan mode how i can block the scan mode
In order for your radio to scan, it would need one of the side buttons programmed to scan. Usually the top side button is programmed for monitor/sticky monitor, and the bottom button can be programmed to any of a number of features, one of them being scan. These buttons have both a long press selection and a short press selection. All this being said, it is possible the bottom button is programmed for scan. Try pressing it a short press and/or a long press and see if it shuts off your scan. To remove scan completely from your radio it would need ot be reprogrammed by an authorized Motorola dealer.
Best regards.
Jun 17, 2012 | Motorola Mag One BPR40 Two Way Radio
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
Bought a used Motorloa Mag One BPR40 at a tag sale and then bought a new one. The used one looks like it was used by a business so it was probably "programmed." How do i get the two BPR's...
Your radios will need to be programmed by a Motorola dealer to match one another. (Usually $15-$25.) The software used to program the radios is a Motorola proprietary software and not for sale, but most dealers have a subscription to it.
The loud buzzing indicates the channel you are on is not programmed.
Best regards.
Aug 10, 2011 | Motorola Mag One BPR40 Two Way Radio
Looking for a 21" antenna for a Motorola SP10
There are custom made antennas for portables. But the better solution is by eradiostore, use a mag mount.1) custom portable antenna, expensive.2) Motorola adaptor to BNC to longer antenna (portable, car type or base station).
3) NO power increase, not only are those frequencies designed for low power the board inside the radio cannot handle the heat and is not changeable or adjustable.
Feb 02, 2011 | Motorola Walkie Talkie 2-Way Radio
Need a free download of an operating manual fo the motorola bpr 40
Nov 07, 2009 | Motorola Radio Communications
Motorola Mag One BPR40 Two Way Radio Logo
44 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
