Question about Husqvarna Garden
3120xp oil tank vent is leaking
Oil tank vent is leaking chain oil. Is it just a case of replacing the vent tube? If so how do you get the old one out?
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
shadtremonky
  • 353 Answers
SOURCE: bar chain oil leaking into case when not in use
if you store it somewhere other than a climate controlled building , the changes in temperature can cause the oil to expand out of the saw a little each time the temp. goes up.
try some absorbent cloth
Posted on Jun 21, 2009
  • 4088 Answers
SOURCE: chainsaw oiler leaks oil out case and no oil on chain
Take the bar and chain off--run the engine--the oiler port from the case should discharge some oil. If none, you have trouble with the oil pump or the tubes to and from it. The oil tank may be leaking at the tank opening for the pickup tube. If oil appears at the oiler port, then there may be dirt/blockage within the oil passages in the bar end. Clean with compressed air.
Posted on Jul 04, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
lemmingleejn
  • 173 Answers
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Posted on Aug 01, 2009
My craftman chain saw is leaking to much chain lubrication oil
I suspect the hole is a tank vent hole. If the tank is hot and full, the oil inside expands and will come out of that hole. There is an oil tank vent assembly, and seems to be above the filler cap. The sears website diagrams are old sketches, hard to read.
Feb 11, 2017 | Garden
Oil tank vent location
there is a tube that comes out of the oil tank and it vents out under the bike somewhere and there is a little filter that is connected to the tube
Jul 13, 2014 | 2003 Buell Blast
I see a few owners of Sportsters asking about oil leaking from the breather tube behind the oil tank. In tracing this vent it is attached to the cases a little behind the starter and above the clutch...
Hi John, make sure there are no obstructions in this vent line such as kinks or collapsed portion and that it is indeed the tansmission vent line if it is you can put an extention on it and run it to the ground away from the rear tire. Good luck.
Mar 31, 2012 | 2000 Harley Davidson XL Sportster 883
1988fxstc. Oil is blowing out of what looks like a oil tank vent hose that ends down by the rear tire. This is not the drain hose, but looks like a venting hose that is open near the rear tire. Anyone...
Without seeing the bike, I would guess that this is the crankcase vent. Originally, the crankcase vent tube came up from behind the oil pump and went to the backside of the air filter. A lot of owners changed the routing of this hose due to oil being blown into the air filter. They simply remove the metal part of the tube and replaced it with a short open ended hose running back and ending just forward of the rear tire.
As for the oil blowing out of the tube, it depends on how much oil blows out of the tube. If it's just a mist that will sometimes coalese into a droplet, this is about normal. But, if it's a steady drip or flowing oil, this is not right.
If the mist is heavy, this could be caused by excessive blowby on the rings creating high crankcase pressures. The use of synthetic oil should not increase the blowby unless the rings are in poor shape, then it will. The use of synthetic oil seems to aggrevate any minor leak turning it into a much larger leak.
If the oil is coming out in a steady stream or pumping the oil out of the engine, you proabably have sheared a key in the scavenge gears of the oil pump and it's not pumping the oil back into the oil tank.
Now there is a vent hose on the oil tank but it should be routed to a fitting on the crankcase that is located just above and slightly behind the top of the oil pump.
Good Luck
Steve
Oct 17, 2010 | Harley Davidson FXST Softail Standard...
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Oil leaks out of the remington electric pole saw. The saw is stored/seated upright and I can't see the problem
Remove the bar and chain, then clean the entire area. Look for leakage at either the small port where the bar fits, or from the motor case itself. Make sure the oil tank vent is open so that pressure doesn't build up from heat. If the leakage is from the case, then look for a crack in the oil tank, or a defective oil line from the tank to the oil pump. Clean the drive end of the bar oil-channels that go out from the large holes to the chain groove on each side. Clean the entire chain groove. It also may be easier to just dump the oil out of the tank after each use if the chain seems to oiling properly. Hope this helps!
Jun 15, 2010 | Remington Electric Pole Saw
Bar oil leaks into storage case when chainsaw not in use???? Poulan Prow, PP4620 AVX 46 cc
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Mar 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw oiler leaks oil out case and no oil on chain
Jun 28, 2009 | Garden
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
