Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Free Agent Desktop Wont turn on
When i plug my free agent desktop into a power supply it does not turn on.
I do not want to send it back as the warrenty is over but i have some important files i need.
Is there any way of giving it power or could i open it up and remove te data and put it into my computer
Please help
I had the same problem and assumed the drive must have been at fault. However, I noticed the power supply (wall wart) wasn't warm as it had been when everything functioned. I contacted Seagate support and they sent me a replacement power supply. It has since failed, but in the interim I found a heavy duty laptop-type powersupply with the same specs. It has worked fine since. Since your unit doesn't power up, I'd check that first. It's the easiest, least expensive thing to do.
Posted on Jan 12, 2009
Cant open my vista backup files on my windows 7
Bro you can use VLC player for that file: follow this steps: 1. install VLC player in your system: http://filehippo.com/download_vlc/download/6e22d5996625004973958dff5998c5e1/ 2. Run or Launch the desktop short cut icon for vlc. 3. Grab the file into VLC player. (this player can play also support a file format .flv) 4. Your done!. God Bless.....
Apr 13, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need to chat with an agent!
1. make sure not only those are properly seated on the led portion of the the case and on the motherboard..
2. also check your power supply motherboard connector is properly seated on the mother board
3. and make sure your power supply switch is on the right postion (110v/115v North america or 220v/230v Europe)
4. make sure the wall outlet plug is working properly. and properly connected to the back of the powersupply
Dec 04, 2008 | E-Machines eMachines Desktop PC
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Can't open files copied to my Seagate Free Agent Go
Ok, install Office onto your laptop and see how it goes. Don't be too panic striken Microsft in general allow one copy of the same program to be running on a desktop and a laptop at the same time on the same license.
It's a home/work thing, Laptop goes to work, desktop stays at home and you can't be using them both right =)
Apr 13, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,019 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
