Question about Plumbing
How to modify Danco handles to work on Valley II faucets
I have Valley II Y28405-74 wide set faucets throughout my home. Valley is OOB and replacement handles for same are available from Danco, however, the Danco handles do not have the molded in piece that comes down to hit the "stop" molded into the faucet stems so that the handle stops turning when the water is shut off. Is there someway to "modify" the Danco handles so that they will stop turning when they are in the right position for the water to be shut off?
    Problem Solver:
  • 9 Answers
Do not modify the handles, just buy the pieces missing. they are available through Danco. Even though i prefer using original parts.
Posted on Feb 21, 2009
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How do I remove a 33055 faucet
www.danco.com
See if their website will be of any assistance.
May 15, 2014 | Danco 33156 Tub And Shower Faucet For...
Valley 3Z-6H/C
Put the large part of the spring into the plastic or rubber washer first, then insert into faucet. I use a little of petrolem jelly for easy instlation.
Dec 22, 2013 | Danco Faucet Cartridge
I bought the Danco replacement stem for a milwaukee faucet(part 4s-6h/c) it is leaking from the handle... do I need to replace the plastic part that runs back into the pipe? Is there an easy way to remove...
Sometimes on the stems on the side the handle attaches is a nut that can be tightened. Inside this nut is a rubber or other type of seal. tightening this nut stops the water from coming out of the handle. If the nut has already been tightened then possibly need to replace this rubber seal.
Sep 02, 2010 | Danco Faucet Stem
Replaced danco cartridge 88198 three times. only
Danco is an after market faucet parts company that recreates parts cheap for hardware supply chains and such. You would be ahead to try and find the brand of faucet you are trying to repair and get OEM parts. They will probably cost a little more, but will hold up a lot better. I hope this helps.
May 18, 2010 | Danco Faucet Cartridge
The handle on my outdoor faucet is broken. I
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
Apr 26, 2010 | Danco Clear Faucet Decorator Handles
Looking for cartridge for Tuscany Brass Tub Faucet Single Handle appears to be Ceramic Disk Type
While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
Mar 16, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Valley II lav. faucets new handles do not have ''stops''
Check with a local plumbing supply or decent hardware store (Ace) to see if they have handle inserts that will do the job. Don't know about Danco handles but I sourced some for another brand that worked well.
Good luck.
Jan 10, 2009 | Plumbing
Plumbing Logo
346 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
