Horizontal blanking left to right - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,496 Answers
What is the brand name of your TV. Horizontal shift is the problem I assumes. If so, you have to enter its service mode options to correct it. Visit the site linked below. There is details about this. Your TV brand too might have been included.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
How do I fix a Sony TV that starts then screen goes blank
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 24, 2015 | Sony Televison & Video
Sanyo lcd tv picture has stopped working
Could be several things going on but the unit will need to be diagnosed to be sure. I would start with checking the t-con/LCD panel ribbon connections. Outside of that could be a defective t-con or LCD panel.
Oct 09, 2012 | Sanyo Televison & Video
My screen is blank about half an inch on both sides.How do I get the screen to widen on both sides? Thank you
Just set your Display setting horizontal or vertical where you feel need, it is easy and simple.
Good Luck
Feb 04, 2011 | Dell Dimension 2400 PC Desktop
Full page is not copied
Hi, did you place paper in tray also horizontal? the paper in tray and on glass must be horizontal if you want to copy A4R size.
DO NOT forget to adjust the blue paper size indicator on paper tray to A4R also.
Also under user mode, under copy sett. you can find option for auto rotate, so copier will adjust size automaticaly.
Jul 17, 2010 | Canon iR 2016i Black and White Copier
Horizontal strip of area is not being printed
May be the problem with laser drive and out of toner. When it happen, shake toner cartridge and replace it. The white strip disappear or not. Please reconfirm. Thanks.
Feb 11, 2010 | Canon LASER SHOT LBP-2900 Printer
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Screen moves
WinXP: Right click on blank desktop, click Properties, click Settings tab. Move the "Screen resolution" slide bar so that the whole screen is used up. In your case the vertical resolution is higher than the screens or horizontal resolution is not high enough.
Screens tends to do scaling. Check the "Native Resolution" of the screen and set it as the Screen Resolution.
Apr 16, 2009 | Acer Aspire 3000 Notebook
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
