AOC L42H761 volume increasing by itself
When I turn on the AOC LCD TV, the volume increase up to 100 and doesnt allow me to decrease the volume. Also the buttons in the TV doesnt allow us to decrease or increase volume or channels. TV is acting very crazy. Please help me with a solution. I will really appreciate
  • faquejai
    faquejai Dec 04, 2012
    This is a Tv, not a monitor. This is a TV LCD AOC model: L42H761. The issue is random, I already leave the Tv disconnected for one day and still failing, never presented a problem before, this is the first time, the issue is that suddenly the Tv start increasing the volumes to the top and I cannot decrease it, when I try it will immediately increase again. Any idea of how I can fix it?
  • 9 Answers
SOURCE: can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Posted on Aug 25, 2007
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Apparently this seems to be a known issue for this model. I called Phillips and they did not even bother asking me to try things like switch off and on again etc...They just said they are going to send someone to pick it up and fix it. I would suggest to everyone to do the same since it has to be free of charge because the problem appears in pretty much every tv set of this model.
Posted on Apr 28, 2008
SOURCE: volume control appears on screen uncommanded and cannot be sent away
I had exactly the same problem. The volume up button was constantly on, causing the on screen display to be permanently displayed. Here is the solution to fix it. This will also work for any other front panel buttons that are misbehaving.
Note: If you monitor is still under warrantee, don't try and fix it yourself - just send it back.
If you open your monitor you will find a small circuit board with a row of microswitches mounted on it. This is the circuit that's causing the problem.
To open your monitor you will need to remove the stand (one plastic cover that unclips by hand and 4 screws that can be removed with a philips screwdriver). This will then reveal two additional countersunk screws that need to be removed.
You can now remove the front cover. There are 4 clips at the base of the cover that can be removed by hand. You then need to pry the cover off, starting at the corner next to the power button. This is really quite stiff and you need to use a reasonable amount of force. Don't worry about the loud cracking sound as each clip along the side releases.
Once the cover is removed you will see the circuit board with the microswitches staring you in the face.
This board needs to be replaced but if you want to fix the problem immediately here is what I did.
Disclaimer - Proceed at your own risk from here on in.
Plug your monitor back into the power and reconnect to your PC. Make sure it's on and still showing the same problem.
The curcuit board unclips and there is a 7 pin connector that also can be unclipped. Remove the board and undo the connector. You don't need to switch off the power.
After the board has been removed for a few seconds, the on screen display that was permanently visible should disappear.
Now I temporarily disabled the malfunctioning button by bending the associated pin on the connector 90 degrees and then reattaching the connector.
How do you know which pin is associated with which button. Trial and error. Simply bend down a pin, and reattach the connector. If the problem persists, unplug and try the next pin.
When you've found the correct pin, straighten the others and reattach the connector.
Clip the curcuit board back in, making sure the connecting cable is clear and doesn't get pinched.
Reassemble your monitor and you're good to go.
The next step is to order a new circuit board from Philips. These should be really cheap (I hope) and you now know how to fit it yourself.
I'm going to try ordering one tomorrow.
Mark Gladding
Posted on Aug 04, 2008
SOURCE: Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Posted on Aug 20, 2008
sipu
  • 51 Answers
SOURCE: Volume to low, need to increase , please help.
install sigmatel audio driver and it will increase ur vol
Posted on May 20, 2009
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Toshiba volume increases by itself
yesterda i ve repaired a laptop with the sam problem. i hav done all reinstallation of windows and drivers.
but this is very funny when i found that the inbuilt key of laptop volume control was pressed automatically so when i try to decrease volume it increases automatically.
so please check for your touchpad drivers and check that any key is not jammed in laptop/desk top.
t
May 09, 2010 | Microsoft Windows XP Professional With...
Remote control will not decrease volume. it will increase volume though. Sanyo HT27546 TV
Check to see if it will decrease on the TV itself,install fresh batteries, mash the down button on the remote applying a little pressure, button may be stuck. hope this helps..
Mar 25, 2010 | Sanyo HT27546 TV
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
Need a manual for L42h761
Dear,
the manual for your device is attached here.
hdtvreview.com/pdf/aoc-l42h761-manual.pdf
good luck
Sep 09, 2009 | Envision Computers & Internet
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Monitor Settings Adjust Itself
try connecting some other monitor to the system, if u do not face the issue, then issue is with the monitor, some hardware fault.
Feb 14, 2007 | AOC LM-727 17" LCD Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
