Question about Refrigerators
Ice buildup in the roof of my freezer.(kelvinator n500c-r)
dididsaythat
  • 291 Answers
SOURCE: Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Posted on Aug 28, 2007
SOURCE: ice buildup on bottom of freezer
yes, the drain is clogged, remove all food from frige and freezer and defrost with a hair dryer,go the the freezer section this is where the issue is, you need to poor hot water into the drain trough located just below the evaporator, chase the drain with a coat hanger with the hair dryer on the coat hanger this with heat up the coat hanger enough to melt and free the clog.
nbcrca:)
Posted on Apr 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Water leaking from bottom of freezer door, and ice
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Posted on Apr 29, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, What brand/model# is this unit? I can help
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
Kelvinator no frost
Please check if there is build up ice around evaporator fan.
Remove rear cover in the freezer and check defrost cycle
Aug 26, 2014 | Kelvinator Refrigerator Fridge Freezer...
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Jun 13, 2009 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
