Question about Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Front Load Washer keeps going out of balance
It appears the wide rubber gasket/seal around the front of the washer door has been torqued out of place. The basket itself spins fine, how ever, is out of balance. Model number GLTF1670AS0
  • dbrown58 Jan 26, 2009
    my new front load washer is out of balance in the tub. When the last spin cycle goes into effect, it acts possessed and walks!
  • cbreezejo Apr 02, 2009
    I checked the rubber seal around the tub and it also seems to be off the track.....the darn thing sounds like it's coming thru the wall during the spin cycle. How can I get the seal back on the drum?? I'm a woman so if you have any ideas, please keep it simple!!!!!
catriver
  • 878 Answers
SOURCE: front load washer
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Posted on Aug 10, 2006
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
mastatech
  • 478 Answers
SOURCE: Rubber seal on Frigidaire twisted during wash.
The only way to realign this is toremove the sping under the lip at the door portion of the seal,this is a tough one youll need a third and forth hand.
Posted on Mar 15, 2009
SOURCE: how do I get the black mold off the rubber seal
Try this! Points 10, 11 12 particularly helpful...
http://www.letsfixit.co.uk/html/washing_machine_hints.html
Posted on Jun 17, 2009
Remove door gasket
There is a spring that goes all the way around the door, just under the edge of the gasket. If you remove that spring starting at the bottom of the door, you should be able to remove the gasket for replacement
Mar 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Wide gray rubber gasket between door and drum is ripped
the rubber will need to be replaced the cost is around $ 150 you can find washer repair service techs under washer repairs in your local phone book
best of luck
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Seems to collect very yucky greyish gunge around door seals which then gets on the washing and won't come off. Is there something I can run through the machine to clean it?
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 21, 2010 | Siemens WFXD8400UC Front Load Washer
My frigidaire washer will not spin, why
You will need to check the door switch you should have 1500 ohms no less than 1400. To check remove wire ring from door seal carefully peal rubber seal off flange. The remove 2 screws holding switch and carefully take out. Check with ohmeter. This is a fairly common problem with that model. For the lowest price on parts go to www.appliancehelponline.com
Mar 28, 2010 | Frigidaire GLTF2940ES Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Apr 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
173 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
