Question about Sharp SL-C3000 Handheld
Help! with sharp el-6710s electronic organizer
I opened my EL-6710s, the data screen was blank, so I assumed the battery was dead. Unfortunately I took the old battery out before reading the TINY print that says to leave it IN and then replace with a new battery in the second slot.
Now when I turn it on it flashes Data Problem PRESS RESET! and there is a tiny "s" in the lower left side of screen. I press reset then the screen flashes RESET OK? I press ENTER and the screen goes right back toflashing Data Problem PRESS RESET! NO matter which button I push the Data Problem keeps flashing on the screen.
I thought it might work to put the old battery back in and start over however when I turned it on, DATA PROBLEM PRESS RESET was on the screen, which was not there before I removed the old battery.
I have had this unit FOREVER (maybe 18 yrs) it has always performed like a champ, so you can well imagine my entire world is on this organizer. If anyone has ANY ideas I am open to them ALL at this point. HELP!!!!!! Please
  • 1 more comment
  • gustavocmk
    gustavocmk Oct 21, 2013
    Hey! I got mine fixed with this procedure:
  • gustavocmk
    press reset and then when reset ok? appear press: 2ND and then ENTER and voila!
  • gustavocmk
    BUT CAUTION!!! THIS WILL ERASE EVERYTHING YOU HAVE!!
    Sergeant:
  • 431 Answers
Is the fuse in good condition
Posted on Jan 10, 2009
  • nematics
    nematics Jan 10, 2009
    the data have been corrupted. u have to remove the battery one by one there will be an backup battery i think u have removed all the battery at once
    Genius:
  • 1,550 Answers
Have you tried firmware update ?.
If not update to the latest and try reset .
  • 1,031 Answers
You may need to reset the organizer's operating system. This procedure is not designed to delete any data; it is simply to reset the operating system.
Some default settings such as time, date, and start up displays will be lost. The data that is stored within the organizer's various applications will not be deleted.
Follow these simple steps:
While keeping the ON button depressed with your thumb, flip the entire unit over so you are now viewing the underside of the organizer. Use a ball point pen and press and release the reset button on the underside of the unit.
Turn the unit over so you are viewing the LCD display. You should see a message that reads similar to the following phrase "Delete All Data - Y/N". After seeing this message, release the ON button and press the letter "N" to indicate you DO NOT want to delete data.
If a reset does not solve your specific problem, please contact the Sharp on will need to call either 1-630-378-3590 or 1-800-310-3012 .hope this helps
I have anEl6710s and can't read the screen , is there a fix or do I need a newer one?
chances are it has been pressed on to hard or extream heat or cold will cause this better off buying a new one
Oct 14, 2014 | Sharp El-6710s 34kb Electronic Organizer
Need instruction book for EL 6710S
Initially, pls try here for the EL-6750, a slightly newer version..
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Sharp Computers & Internet
Sharp el 6710s
im still trying to figure out why my hp 4620 doesn't print or copy
Jan 24, 2014 | Office Equipment & Supplies
How to reset Sharp el 6710s
Hi! Today I had the same problem, after you click on reset, the screen will show you RESET OK?, there you just need to press 2nd and ENTER key, the screen will show the word BUSY for a while, and then it will be reset; you'll be prompted to enter your business data and you're done.
Dec 04, 2012 | Sharp EL Office Equipment & Supplies
Where do I get a manual for my sharp el 6920 pocket organizer.
You can get it from the manufacturer's website
http://files.sharpusa.com/Downloads/ForBusiness/SmallElectronics/Organizers/Manuals/Archive/org_man_EL6920.pdf
May 20, 2012 | Sharp Office Equipment & Supplies
Can you tell me how to reset my organizer
push the reset with pencil and then 2nd edit & enter
Mar 08, 2010 | Sharp Personal Organizer & Spanish/English...
EL*6710s
Try this: after pressing reset, then press 2nd and enter.
Jan 10, 2009 | Sharp AL 1631 Copier
Sharp SL-C3000 Handheld Logo
1,633 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
