Question about Dryers
Drier works but will not heat - Dryers
    Genius:
  • 2,920 Answers
Check the heater coil and the limit switches they commonly go out on dryers and will prevent you from getting heat
Posted on Jan 10, 2009
No heat WD62 on drier or water heater
Check the thermistor is plugged in,,,it's next too heater
Jun 13, 2013 | Washing Machines
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Drier works just no heat. need to know where the
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 25, 2010 | Whirlpool Inglis IP8200 Dryer
KGYS850LT / KGYS850LE / KGYS850LQ Gas Dryer: The drier is working fine just no heat?...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 18, 2010 | KitchenAid KGYS850LT Gas Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
The drier has no heat.
I have a repairman scheduled for tomorrow.
Thank you for the followup.
May 27, 2009 | KitchenAid Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
DRIER OVER HEATS, WORKS ONLY ON "FLUFF" CYCLE
You need to have the thermostats tested by a qualified servicer.
May 21, 2008 | Crosley CDE6000 Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
