Question about NexxTech DP3222 DVD Player
Nexxtech 1519004 remote code
Im looking for the code for this remote
I have an RCA universal remote control CGEU401 and have successfully programmed the sony TV. However I have been unable to do so for the Nexxtech VCR/DVD combo model 1619001. I have tried code searc
If there is no setup code in the code list of the remote to serup your Nextec VCR/DVD with RCA universal remote, the remote cant be set to that device. That is all.
Apr 15, 2012 | Televison & Video
I need to know how to program my nexxtech 5 in 1 Universal remote control Cat # 1519004 to my T.V which is a Toshiba
Directly from the manual:
Code Programming
The P (Program) button is used to program the remote. You can program the remote using the code for your brand of device from the code list, or search through the library of codes until you find a code that works for your device. You can store any kind of code under any mode (except TV). For example, you can store a VCR code under the SAT button, or a DVD code under the VCR button, etc. However, you can only store TV codes under the TV button.
Direct Code Entry
1. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays
lit.
3. Enter the 3 digit code from the code list. Note: The red indicator turns off after a valid code entry and flashes for an invalid code. 4. With your device on, press Channel Up. If the device responds, no further setup is required. Note: If some buttons on your device do not operate, try one of the other codes for your brand.
Toshiba TV Codes
0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
You can download the fuel manual and code list here: http://files.remotecentral.com/download/472/1519004-manual.zip.html
Jun 01, 2011 | Televison & Video
I have a nexxtech universal remote and a philips dvd player, How do I program, lost the manual
i both a universal remote control from nexxtech for my electrohome tv a month ago .
And its not working anymore , i lost the code to reprogram it . Can you help me to get that code
Sep 02, 2008 | NexxTech PDN-0705 Portable DVD Player
Need universal remote control codes
Well I have a nexx tech universal remote control model 1519001B but I lost the code list and I nedd the code for a JVC tv.
Mar 19, 2008 | Televison & Video
Remote code
i need the codes to program to a svlania
Feb 02, 2008 | Philips Magnavox Learning Universal Remote
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Codes for a nexxtech tv remote control 3 in 1
Wiki works, folks.
http://kbase.x10.com/wiki/Four_Digit_Universal_Remote_Code_List
All the codes for Nexxtech Universal Remotes, including Panasonic.
Cheers!
Dec 28, 2007 | Sanyo PLC XU35 Multimedia Projector
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
NexxTech DP3222 DVD Player Logo
125 people viewed this question
Top NexxTech Televison & Video Experts
jasbo
jasbo
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
