Question about Sharp Office Equipment & Supplies
Changing default settings on ricoh mp 4001
I'd like to change the default settings on our Ricoh MP 4001. Right now, it is programmed to copy the front side of a document. We'd like it to automatically copy the front and back side of a document.
Bubbabear64
  • 2794 Answers
SOURCE: RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Posted on Oct 26, 2008
  • 86 Answers
SOURCE: How to enter the maintance mode on a Ricoh MP 3350
If you want to enter in Service program mode please,
press Clear (yellow) button, 1 0 7, and press and hold Stop (orange) button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Posted on Jan 28, 2010
  • 114 Answers
SOURCE: scanrouter v2 lite at ricoh aficio MP 4000
you dont need scanrouter for mp 4000
Posted on Mar 21, 2010
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
How do i set Ricoh Aficio MP-C305SPF to factory default
Print on SMC list and setting the value on the factory level.
Feb 26, 2013 | Ricoh Aficio MP-C305SPF Color Copier :...
Setting the duplex printing for RICOH Aficio MP 3351
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
I would like to install ricoh aficio MP 2000 Le printer driver form the net.
how to install ricoh mp 2000le printer driver for windows 7
Jun 19, 2010 | Computers & Internet
How do I change default scan settings on MP161
you can remote into it by a web browser and ip address then log in as admin and no password.
Mar 18, 2010 | Ricoh Aficio MP 161 Black and White Copier
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
