Question about KitchenAid KERA205PSS Electric Kitchen Range
How to replace bake oven element on kitchen aid ykerc507/hw4
2 Suggested Answers
  • 574 Answers
SOURCE: Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
Posted on Apr 05, 2010
How do I replace the bake element of the upper oven of the kitchen aid kebc208kss02 double oven?
Take the info. Off the oven, make, model, etc., to parts store and get replacement. The part should come with instructions on replacement.
Nov 23, 2014 | Kitchen Ranges
Kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Aug 07, 2008 | KitchenAid Architect Series KEBC107KSS...
How do I replace the bake element of the upper oven of the kitchen aid kebc207kss02?
Here is a link to the element and there is also a video on that same page to show you how to replace the element. Whirlpool W10207400 Elmnt Brol AppliancePartsPros com
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Apr 05, 2010 | KitchenAid KERA205PSS Electric Kitchen...
How to replace bake oven element on kitchen aid model KERA205pass5
This is a very simple repair. The following link explains how to replace the bake element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If you have not purchased a replacement element yet, the part number is 9755770. The cheapest place I could find the element was appliancepartspros.com for about $54.
NOTE: The element may be slightly mishapened during shipping. If you have to straighten the element to install, use care that you do not crack or break it.
If you have questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Sep 16, 2009 | KitchenAid KERA205PSS Electric Kitchen...
How to change hidden element in kitchenaid oven
you have to remove the plate that covers that element
Jan 03, 2009 | KitchenAid Kitchen Ranges
Replaced bake element but range won't turn on
Not a happy circumstance.
An old message and you have probably found the problem by now; if you have, you might post it back here as a comment to aid others.
There may be  fuse mounted inside the back panel of the upright. Unplug the range before removing anything that may expose lethal voltages.
Happy New Year
Oct 25, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
KitchenAid KERA205PSS Electric Kitchen Range Logo
94 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
