Question about Dayton Dryers
3c215g fan need pull chain switch - Dayton Dryers
ceiling-fans
  • 20 Answers
SOURCE: Pull Chains Replacement
Replacements are available at Home Depot and Lowes. This is a regular 4-wire single-layer switch.
Mark the old wires, so you know which ports they go to in the switch (marked L, 1, 2, and 3) -- then remove the old wires by pressing a paper clip into the hole of each wire while pulling firmly on the wire. Then just push the wires into the new switch, into the marked holes.
I hope this helps! If you have any more questions, please feel free to ask!
Posted on Jun 17, 2008
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
  • 26 Answers
SOURCE: Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Posted on Aug 17, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
How do I get a diagram for a 3 way switch
Do you mean 3 speed switch? The question says your fan has a remote! Pull chain switches are different. If you need a pull chain switch call 1-888-830-1326 with the model # of the fan.
Aug 03, 2014 | Hunter 52" Ceiling Fan With Light And...
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
Old fan switch has 4 wires, new one has 3. A Ceiling fan light switch is for the fan, not the light, correct?
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202191016&langId=-1&catalogId=10053&PID=500871&cm_mmc=CJ-_-500871-_-10368321&cpncode=00-29062147-2&AID=10368321&cj=true&srccode=cii_9324560&locStoreNum=577
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
2) Ceiling fan pull chain switch is for the fan only.
Jul 18, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I need to reverse direction of fan
mcdevito75 here, Close to the ceiling but still on the fan motor shroud should be another small pull chain switch, this pull chain switch is the fan reverse switch, the switch may also be a toggle switch but I doubt it. Look close to the other pull chain switch for the fan, for the reverse switch.
Jul 26, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Chain switch broke
The light fixture then the fans lower housing needs to be removed to gain access to the pull chain switch
May 03, 2010 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Center pull chain came out the one that turns
you need to replace the switch . which is where the chain came out
Oct 31, 2009 | Hampton Bay 52 In. Polished Brass and...
Remote does not consistently work
You can include a push chain switch, if theres enough room in the ceiling fan housing. This is a job for a professional electrician or appliance serviceman who is willing to modify an appliance. It will need to be tested for intrinsic safety and the work should carry some sort of warranty since the pull chain modification (if made on the ceiling fan house) will likely void any warranty. Instead, I advise that the pull switch could be intalled elsewhere in the room. However, it still remains a job for a profession electrician who can install the pull switch in parallel with the existing switch.
This would however be able to control all three fans with just one pull switch if you wanted.
May 10, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
109 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
