Question about Music
I think my Korg Triton Extreme Bricked!
If (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts || {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = "Need Help w/Triton EXT"; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "narc_tunez@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.annotationSet = { "lw_1231615422_0": { "text": "SYSTEM ERROR", "extended": 0, "startchar": 372, "endchar": 383, "start": 372, "end": 383, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 0.410093, "relScore": 7.85536, "type": ["shortcuts:/concept"], "category": ["CONCEPT"], "wikiId": "System_Error", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "and the keboard froze and gave me this Erroe Code: SYSTEM ERROR Type: 0x00000000 Code: 0x000000E0 Info1:0x0C0ACE8B A033: data is 0x65F37F0C at", "metaData": { "visible": "true" } } }; YAHOO.Shortcuts.headerID = "ef9129ba924e0dd105ff39da1d5228b8"; I was loading a ksf file that I keymaped to the Triton Extreme and have used many times, but this past friday when I went to load it, I press the sequence button and the keboard froze and gave me this Erroe Code: SYSTEM ERROR Type: 0x00000000
Code: 0x000000E0
Info1:0x0C0ACE8B A033: data is 0x65F37F0C at 0x0C0ACE88 Info2:0x0C0ACE8B Current Task ID: 4 I dont know what to do, if you can be of some help I will gladdly appreciate that from you...I am so sad that this happend to my keyboard..Thank you!
  • Anonymous Mar 02, 2009
    i have the same problem all of a sudden some of my patche swont work. and i got a system error sign
5 Suggested Answers
  • 40 Answers
SOURCE: can I plug my American bought triton in European
Only if it has a switch that changes over to 220. I beleave, if not ten you will have to get a power inverter for the power difference and plugs for the different styles that they have over in europe. I hope this helps.
Posted on Aug 15, 2009
  • 4234 Answers
SOURCE: Broken Triton push button
I am not familiar with your exact model, but if the plastic "hinge" for the button has broken, it is possible to "fix" it. This is not a DIY repair though. Can you tell me where you are located so I can perhaps suggest a repair location?
Thanks,
Dan
Posted on Nov 04, 2009
  • 1138 Answers
SOURCE: How do I play the O1WFD sequencer through the Triton Pro X??
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
Posted on May 18, 2010
  • 5603 Answers
SOURCE: my Korg Triton Le has Lost all of its sound and i
Try this site:
http://www.tritonhaven.com/
Posted on Mar 08, 2011
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
CRACKED LCD ON A KORG TRITON EXTREME...
Try this link:http://www.korgparts.com/content/estore_list.asp?category=3&catname=Korg
Oct 19, 2010 | Music
May 16, 2010 | Music
Thanks,
Dan
Nov 04, 2009 | Music
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from korg.com. You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
Music Logo
137 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
