Question about Refrigerators
Why does the defrost water not go into the tray?
The water from the defrost goes inside the fridge, while the tray below remains empty.. ..It's an Amana refrigerator..
    Problem Solver:
  • 9 Answers
The drain hole in the drain trough is probably clogged up with some gunk.
Use a turkey baster and VERY VERY hot water to try and clear the drain line.
Posted on Jan 10, 2009
Auto defrost seems to not be working because the drip tray is dry is it supposed to be like this or wet most of the time freezer is cold but not freezing and fridge isnt cold i have temp gaugers in both...
either un plug the fridge and let it defrost manually, or empty and flush out drain line with a hose or hot water. when it goes into the defrost mode, water should drip into the pan..
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
FRIDGE WITH FRENCH DOORS AND FREEZER ON THE BOTTOM. WATER IS LEAKING FROM SOMEWHERE AND SETTLING UNDERNEATH MY DELI DRAWER TRAY. SOME OF THE WATER IS FROZEN. I HAD TO TOWEL THE WATER UP AND PRY OUT THE...
Your model must also have an evaporator on the top section because if the fresh food section deli has water below the trays you either have a door seal leak allowing moisture in or the fresh food section evaporator drain is also blocked. I really think your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions I will be here so please ask, Thanks, Sea Breeze
Jun 29, 2011 | Refrigerators
Maytag side by side fridge not connected to any water source stand alone system except electricity. approximately 500 ml puddle of water underneath vents are clean but unsure where water is coming from...
This is what it sounds like to me. The defrost system melts away the frost in the cooling coils every 6 or 8 hours. This water goes into a tray at the bottom of the freezer compartment. there is a drain spout in the bottom of the tray. The water then goes through that into a plastic drip pan. This sits behind the vent below the doors. While the fridge is running, the water evaporates out into the the room. If the pan is missing, or cracked for some reason, the water goes onto the floor.
And that's were the water is coming from. The Fridge is not broken.
With the model number of the fridge, probably located on a placard inside the fresh food compartment, or possibly the freezer compartment, you can order a new drip pan from a parts supply house for something like $25.00 The easiest thing to do would be to put in it's place an inexpensive aluminum pan of sorts. that usually will do the trick and save money.
I hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | Maytag MSD2758G Side by Side Refrigerator
There has been a spillage inside the fridge. There is now a smell coming from behind the fridge. How do I clean it?
below the unit is a tray for defrost water to evaporate.remove front grill,slide out tray carefully and clean with soap and water
Sep 27, 2009 | Refrigerators
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
STANDING WATER ON TOP SHELF
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from top of fridge then freezing under crisper's
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water pooling in base of fridge
Jan 08, 2009 | Engel 43 Qt.Portable Freezer.
My hotpoint ffa74 fridge freezer drainage hole in fridge compartment never drains away the water. have emptied and defrosted but made no difference
Defrost the fridge. I recommend at least 24 hour period, it's normally quicker. After it has defrosted empty the tray at the back by simply unscrewing the tray and removing the little black rubber tube. To test that it has totally defrosted pour coke down the drain inside the fridge with the tray back in, this should filter into the tray. Clean the tray again and insert black rubber tube and tighten screws again, job done.
I had the same problem but it was all sorted within 16 hours as it defrosts quickly.
May 02, 2008 | Refrigerators
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
