Question about Samsung PCJ614RF 61" Rear Projection Television
Television THE POWER TO THE TELEVISION KICKS OFF AT ALL DIFFERENT TIMES.SOMETIMES BEFORE IT HAS TIME TO OVERHEAT.TO GET THE TELEVISION TO COME BACK ON I HAVE TO UNPLUG IT USUALLY FOR TEN TO FIFTEEN MINUTES.TELEVISION MAY PLAY FOR UP TO A WEEK OR IT MAY KICK OFF FIVE OR SIX TIMES IN SIX HOURS.
  • 1,476 Answers
Sounds like you could have bad solder connections. If you have the experience remove all boards and look for cracked or cold solder joints and resolder anything suspicious. If that doesn't solve the problem you have a component which is randomly shorting out and you will need to find a reputable repair shop to take a look at it. Good luck.
Posted on Jun 13, 2007
Television takes long time for picture to come on. sometimes turns on briefly then off again and power lamp flashes several times.
could be lamp starting to fail. i suggest calling panasonic customer support i think this model has a 5year warranty on the lamp
Dec 22, 2010 | Panasonic PT-61LCZ70 Television
TV does not show picture when turned on. Some times it does not come on. when it does it goes to a split Bright green screen, After that it will go to a lot of different screens with lines, full screens of...
It is possible that TV processor could have some garbage it do to a small voltage surge, and if you leave your set, unplug from the wall for 40 min,. that will reset it back to normal. If thgat don'rt work then remove the back and check for a couple of bulged electrolytic caps on the power supply nthat need change, or change out the power supply.
Nov 12, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Hi there i have a Bravia # KDL-46VL150 Television
Problem is with the backlight and will get worse over time. Return it if you can. Otherwise, have it repaired by Sony as this unit comes with a 2-year warranty.
Jun 12, 2010 | Televison & Video
Our D52W198 was mfgr'd. Aug 2004. Sometimes it
A television shutting itself off may mean a few things:
  • Bad lamp (most likely the cause)
  • Overheating
  • Bad power supply
  • Bad ballast
To properly diagnose your television, i'll have to know more about the symptoms. You can start by moving the television away from any walls. This will give it better ventilation and cooler operation
Mar 26, 2010 | RCA D52W19 52" Rear Projection Television
Tv switches off
set goes on 20 seconds it goes off
Feb 24, 2008 | RCA TruFlat 27F520T 27" TV
Sony kv32fs16 problem
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Samsung 62" rear projection t.v. model # PCL6215R
The most likely problem is a bad solder connection on one of the circuit boards. If you have the skills, remove the boards and look at all connections for cracked solder joints or cold solder joints. Resolder anything suspicious.Good luck.
Jun 11, 2007 | Samsung PCL6215R 62" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Another question
you can pull the plugs inside tv to convergence yoaks if tv starts up . you will need convergence ic,s
Apr 13, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Samsung PCJ614RF 61" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
