Question about Proform XP 580 Trainer Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
    Top Expert:
  • Proform Master
  • 12,223 Answers
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
loud clunking noise in rear roller of proform 580  - 11_29_2012_11_30_43_am.gif
Posted on Nov 29, 2012
4 Suggested Answers
  • 103 Answers
SOURCE: Proform 400GI Treadmill making a very loud noise,
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Posted on Nov 13, 2009
2manyhobbies
  • 127 Answers
SOURCE: I have a Proform 590T
It might be motor bearings or a roller. Remove the drive belt and run the machine.
Icon has a good warranty program. I am a service tech for the company working in Canada. If it is only 3 months old, call ICON and arrange a service call from a qualified tech.
1-888-533-1333.
Posted on Dec 15, 2010
  • 84 Answers
SOURCE: I have Proform Treadmill Model 831.29406.2 , the
treadmilldoctor.com
Posted on Mar 08, 2011
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
Just starts and stops immediately
1) Lube the deck belt, maybe is worn, to due the lack of maintenance.
2) Lube the rollers bearing front and rear very well.
3) TEST THE voltage motor input, if there are voltage, the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
May 14, 2012 | Proform XP 580 Trainer Treadmill
I have a Pro-From Crosstrainer xp 580s, walking on the belt isn't smooth and it makes a squeeking noise
You need to adjust the roller tension, The adjustments are at the sides of the treadmill by the rear roller. Sometimes there is a cover over them.
Mar 10, 2012 | Proform XP 580 Trainer Treadmill
I have a Proform 590T treadmill that is 3 months old - about 60 - 75 miles on it and it has become noisy. Not a clunking just a loud hum. It is the same noise regardless if you are walking on it or just...
1-888-533-1333.
Dec 14, 2010 | Proform 590T Treadmill
I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Jul 31, 2010 | Proform Exercise & Fitness
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Jul 28, 2010 | Proform Exercise & Fitness
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Proform XP 580 Trainer Treadmill Logo
396 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
