Question about Health & Beauty
Kitchen scale model z17489
Battery for above product
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
awa13
  • 78 Answers
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Posted on Mar 21, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Nov 22, 2017 | Salter Health & Beauty
Am trying to add clarification to an earlier question. The scale I am asking about is a wall mount kitchen scale: the make is Salter, the model 1601. It worked fine for several years until I changed t
Is it possible you put the batteries in the wrong way? Sometimes a device will still have power in that situation, even though it won't work as expected. Try a new set of batteries, but clean the contacts in the battery compartment first, and double-check the battery orientation.
Dec 20, 2014 | Salter 2001 electronic kitchen scale
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
Mar 20, 2010 | Health & Beauty
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Hope that helps!
Aug 04, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
