Suddenly stopped working ,won't restart my PC?
My PC suddenly stopped working,if i try to restart no display but fans inside CPU are working fine,power led is ON.removed motherboard and replaced it,still unable to open the bios also i am unable to know what is the problem,any help?
  • 57 Answers
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Posted on Nov 29, 2012
SOURCE: Motherboard ABIT KN8
I just lost my fourth KN8 motherboard and it always seems to take out the power supply unfortuneately. One I returned for the 3 year warranty and as a replacement it worked less than a month. These were on 3 different machines(cases and power supplies of various suppliers) so the mother board is the fault.
Will be hesitant to use ASUS boards again even though this may be isolated to this board only.
Posted on Feb 05, 2008
  • 101 Answers
SOURCE: atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
Posted on May 06, 2008
map9966
  • 2351 Answers
SOURCE: pc not on
Please list the name & model number of the motherboard.
M
Posted on Jun 09, 2008
SOURCE: My Intel D845EPI/D845GVSR MB processor does not boot up. No BIOS or POST is dispayed on the screen
vfsfsf
Posted on Oct 23, 2008
zohail
  • 1223 Answers
SOURCE: System not rebooting after BIOS update
may be u have flasshed a wrong bios to ur mother board u have to take it to service centre it basically bios dead can be repaired at cost , try removing RAM and then re install them see if it works
Posted on Feb 21, 2009
My system suddenly hang when we restart it, monitor does not get any signal. After when we get rid hard drive motherboard was working. on other system my HDD is working fine.
This is usually dust clogging up the CPU cooler.
When the owner of the PC forgets to clean the fins and the fan of the CPU cooler it plugs up with dust and dirt and looks like the inside of a vacuum cleaner.
There is not enough airflow and thus not enough cooling, so the CPU overheats and the safety circuit shuts the CPU off until it cools down, and the CPU will not reboot the PC until it is cool enough that the safety circuit can reset.
First step remove the CPU fan and check the fins of the CPU cooler. If they are clean, the problem is usually somewhere else.
Oct 03, 2015 | Intel DG31PR Motherboard
Hello, I have a problem with my PC. I'll be
connor,no input you write it can be a easy thing as the monitor-cabel is not tight enough fasten.check that first .if the problem don't go away you have open the computer and remove the videocard clean the cards slot with caned air short poffs never shacke the can.now reseat the card and hope at that did the trick.let me now if ok
Jul 20, 2013 | Computers & Internet
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
IT SUDDENLY RESTARTS WHEN WORKING A PROGRAM LIKE 3D MAX.
It could be a software or hardware issue. Use an antivirus to do a full virus scan on your system then try again. If that doesn't solve it, check to see if all the fans inside your CPU are working.
Nov 14, 2012 | HP Z400 Workstation FL843UAABA...
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
Pc suddenly powers off
that can be meaning if the processor is Not Supported with your motherboard,or the New Processor is not in good condition (can be Over Heat or damage).
Processor over heat or damage can be because the HEAT SINK (white or grey pasta at the top of processor) is not enaugh to cooling the processor or,the fan Proseccor is Dirty.
Jan 18, 2012 | Computers & Internet
K9N6PGM2-V MSI Mobo no display no beeps after virus attacked,im installing Anti Virus AVAST it stop suddenly the screen becomes dull and grey with white line,so i restarted my PC and it doesn't display...
Your VGA device of motherboard might have problem. and it also can be caused due to some IC failure... you will have to repair your Motherboard as soon as possible. if it dosen't worrks consider replacing your Motherboard.
Sep 01, 2011 | MSI K9N6PGM2-V Motherboard
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
My computer suddenly quit working. The power just went off
The most common reasons for that are
1. power adaptor or battery isn't working - power problem. Some laptops require the battery to be in the machine even when it's running of the adaptor. If it runs out of 'juice' it will just go off suddenly.
2. overheating - It can get full of dust and dander and overheat the cpu which will also cause the machine to go off suddenly. It shuts off to protect the cpu from burning up. Sometimes if they get hot enough it can still take out the cpu... If the cpu fan stops working it will also overheat.
3. Control Panel - Power settings - check to see if there's a timer set to turn it off after so long etc.
Jul 08, 2011 | Fujitsu LifeBook A1110 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
