Sharp AR 5623 L1 Error - Office Equipment & Supplies
5 Suggested Answers
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 257 Answers
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Posted on Nov 24, 2009
  • 5 Answers
SOURCE: code L1 on a sharp AR-153E digital copier. Any
L1 code means problem with scanner unit. cheque to see if scanner is locked if not , lube rails and ck scanner motor.
Posted on May 23, 2010
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
How do i clear error f2 70 on sharp ar 5618
Service Manual SHARP AR 5618 5620 5623 SME honestly I did not see this code in the owners manual but it should have a number you can call to ask how to clear it. I've noticed a few people have asked this question for this specific product but haven't gotten any answers. If you do find the solution please post it for people with the problem in the future :)
Sep 27, 2015 | Sharp Office Equipment & Supplies
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
Sharp ar-m205
L1 indicates the laser mirror motor is bad. The laser would have to be replaced to fix properly.
Jul 29, 2010 | Sharp AR-M205 Copier
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
Dec 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
227 people viewed this question
k24674
jasbo
jasbo
