I have just signed up to bt braodband and got a bt home hub. As a result I have a spare BT voyager 54g wireless network modem. Can I use this to print wirelessly to my lexmark printer
    Problem Solver:
  • 20 Answers
You can't use wireless adapter to hook printer to wireless network. You need a wireless print server. Example is Linksys or DLink Wireless-G PrintServer.
Posted on Nov 22, 2009
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
How do I connect my Netgear DGND3700 router to Fibre internet (BT infinity)
Hi there
Your Netgear router will not connect to BT Infinity directly as the built-in modem is ADSL/ADSL2+ and Fibre requires a VDSL modem as in the HomeHub5 or the BT Openreach modem. Either of these can be used with your Netgear as a subsidiary router/access point. You may now be able to get a router with a VDSL modem built in but 3 years ago it was really only available from BT and BT did not support other makes.
Hope this clarifies matters though perhaps not too helpful
Nov 08, 2014 | Network Computing Devices (NSH800S/A)...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Connecting TLWR743ND to BT hub
I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
May 04, 2012 | TP-LINK Router TLWR743ND 150Mbps Wireless...
Bt home hub setup download
Possible reason would be that BT normally 'lock' their hubs and modems etc so that you can only use them with the BT service. Need to contact BT and 'ask nicely' if they can unlock the hub for you (not 100% confident if they will) failing that you will need to either purchase equipment or use equipment your new supplier issued
May 01, 2009 | Computers & Internet
Wifi connection to BT Home Hub problems
Make sure you do not have any third party software running in your taskbar that deals with wifi connection if your trying to use the windows connection. this is what i do. its better, and more simple. Home Hub does not work well with non BT software. If your not sure, turn any wifi connection software off. i.e if any came with your wifi device. and then click on the start button. and click connect to on the right lower side of the start menu. You can use almost any wifi device with these devices. your best bet would be to let windows try to connect to your home hub. Also are you typing in your WEP key. correctly. How far away from the hub is the wifi device. Is windows wireless zero configuration off in system services. unliekly. but worth a look. I have had a home hub for three years and i have to admit they are a nuisence. The BT Voyager wifi works ver well. just in case there is some kind of incompatibility with your device, i highly doubt it though. Good Luck.
Apr 27, 2009 | Archos 705 WiFi Digital Media Player
Cannot connect to wifi on our bt home hub
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
