WD73927 sound cuts off but picture stays
Have a WD73927 Mits DLP. In the process of changing the color wheel but before I tear into it...it just started this new problem. The sound stops but the picture continues to play for an extended period then the set shuts down. You can turn it back on immediately after it does this and it works fine... but may operate for hours before doing the same little cut out. Any ideas while I'm going to have it tore down anyway? It does display a message on the screen when you turn it back on that says AV disc is reconnected ?! Thanks
  • edsoper
    edsoper Dec 30, 2012
    Soft reset didn't cure the problem.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Try the soft reset this model should have with set on Menu,1,2,3 enter.
Posted on Dec 22, 2012
silly girl
  • 513 Answers
SOURCE: Picture cuts out
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. The five blinks(count them again just to be sure) is an error codes that stands for the following: "FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly." So what is the AKB? It is Auto Kine Bias; a circuit that holds the video OFF until the picture tube (kinescope) is warm enough to run video. So, if there is trouble within the AKB it may not be turning on the crt. Or, the crt could be cold, or there could be power supply problems (which I favor because the audio is gone, too, which means it is not a "video only" matter). Therefore, I do not favor replacing the C board (or A board as indicated in the url above). I favor finding out why the AKB circuit is not functioning. It is necessary to get the set to come ON long enough to make sure the crt is heating up. You may have to manually defeat the protection circuit and force the set to come ON. If you can find the ON relay you may be able to hold it ON manually - at least long enough to find out more symptoms, but not too long or some further damage may occur. Go to: http://www.schematicsforfree.com/archive/?path=Sony%2FVideo where you may find a schematic or service manual for this set - or one that is close/similar enough to be of great value. Last comment: Some sets will, upon failure of the AKB function, after a few seconds, go into diagnostics - which is similar to protection. So, the audio may be working okey. Turn the set on with the volume up; if you hear audio for the until the set cycles into the flashing light routine it means the audio is really good. So, check that carefully. You may have to do a hard reset to cause the AKB function to reset. So, do this: Unplug the power cord for 4 hours or more. That will reset everything. Hope this helped, or gave you a general idea, but please don't take a further step unless you know the safety issues involved. Good luck
Posted on May 22, 2006
cammykins
  • 149 Answers
SOURCE: No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Posted on Sep 24, 2007
  • 179 Answers
SOURCE: Samsung HL-R5067W "Powering Down"
the hlr series had a few problem with intermittent turning off. one was the lamp door cover switch, the other was the thermostat.. neither one is very costly and a good tech should be able to replace bothe parts at the same time..
Posted on Nov 29, 2007
davebies
  • 43 Answers
SOURCE: no picture but has sound
If the screen turns bright blue then you may have a bad blue crt(picture tube) I suggest an on site diagnosis by a Sony ASC to verify if it's the crt. Crt's can run up to $150.00 plus installatin and alignments.
Posted on Jan 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a Samsung HLN467WX
I suggest going to the following link. they will have the service manual for your model available by email after purchase and they offer free tech support to help you with the diagnosis and repair of your DLP heres the link in case you want it.
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
May 29, 2012 | Vivitek V37655 56" DLP TV
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
My Samsung has had a loud buzzing sound for a few weeks now, and over the past 3-4 days, it has been in black and white at times. Now, there is no picture, just sound only. I have read blogs where people...
The noise you heard was the Color Wheel going bad. This part acts the same way as the large color wheels people use at christmas time for changing colors on there trees, house, etc. They do the same thing in a dlp set except spin a whole lot faster and combined with the Digital Light Processor it gives you your primary colors. If the speed starts to slow down because of the bearing going bad then you will start to notice a B&W picture and the noise. Eventually the picture will not come on because the Microprocessor has detected an error and will not let the end process start.So, there we have it. Have a tech verify this and see if the Color Wheel is still available as a single unit or complete with the Light Engine which in that case would not be worth repairing.
Nov 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
