Question about Toshiba Televison & Video
Toshiba regza 40xv654u circuit board replacement
3 Suggested Answers
  • 3 Answers
SOURCE: broken lcd board
if you still have this unit would you be interested in selling it if so please email me at vtcpuguy at yahoo dot com
Posted on Sep 18, 2008
brownline45
  • 310 Answers
SOURCE: WHERE CAN I FIND A REPLACEMENT ON/OFF SWITCH (FOR
good day just go to Toshiba service center.all parts you need have them all.
Posted on Jun 20, 2010
My Toshiba Regza can run for about an hour before the sound goes on it..it gets very loud and all it does is make distorted loud noises.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 10, 2015 | Toshiba REGZA 52XV540U 52-Inch 1080p 120Hz...
I dont have any sound on toshiba t.v 42RV530U
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 05, 2014 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba regza 42rv530u has picture no sound
Check its system settings first.[PAL, NTSC, SECAM] etc. Select the appropriate system adopted your country of set this setting to 'Auto' if the TV is a multi-system compatible one. If this setting is correct and you still faces this problem, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jul 26, 2014 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba 32" regza TV great picture but no sound how can I solve this please.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 14, 2014 | Toshiba REGZA 47HL167 TV
Toshiba Regza 42RV535U42" LCD HDTV when i turn it
Check the power going to the inverter board (24V) if ok...replace Inverter board....
Oct 28, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
My toshiba regza has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Aug 07, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
32'' Toshiba Regza difficuut to switch on from plug & standby
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 22, 2017 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
MY REGZA IS SHOWING NO PICTURES,its like a radio.
Jun 11, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Televison & Video Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
