Question about Kenmore Elite Oasis 27052 Top Load Washer
Ld code, will not drain, will not turn off
Got a Ld code, machine did not drain. checked hoses, they were fine. Machine will not turn off, have to unplug to turn off. Machine is just less than 2 years old. Crappy whirlpool and kenmore!!
    New Friend:
  • 88 Answers
There is something stuck in your pump remove the back panel and you should check the drain pump the pump that is on the bottom left. good luck
Posted on Jan 11, 2009
Washing machine not draining, LD error code
Through the lower tube of the tub may be able to remove the item of clothing.
Dec 22, 2013 | Kenmore HE2 Washing Machines
The machine stopped at 13 minutes to go then showed an LD code. What does this mean?
Is this a machine made by Kenmore?
An LD code n a Kenmore machine means Long Drain.
Check the water inlet hoses for kinks or clogs.
check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! :)
Jun 09, 2011 | Washing Machines
Have Kenmore elite oasis that is coming with Ld code then F32 which means machine is taking too long to drain. The pump runs fine pumps all the water out. The hose is not clogged water drains freely....
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
LD = LONG DRAIN
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2010 | Kenmore Oasis HE 27062 Top Load Washer
My washer is indicating a "ld" problem. I have readjusted the load and restarted the machine but it continues to stop and the "ld" code keeps coming on. I have a very small load in the machine so I know...
Hello, the "Ld" error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
  • Is the drain hose kinked or clogged?
  • Check the drain pump for clogs. Is it running?
  • Is the drain hose height greater than 96 inches?
  • Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
  • Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
  • Thanks
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD mean
The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso has a code of ld
Well error Ld means - Long drain - The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. Anyway you can please check out the following steps -
Is the drain hose height greater than 95 inches?
You can try to reset your washer by Pressing STOP/CANCEL. Please check out all the above steps, post comments if further you have the same problem.......
Good Luck!!
Thanks
May 12, 2010 | Washing Machines
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine will not turn on
The "LD" or "long drain" code usually indicates a drain or pump related issue. It's not only if the water drains, but how quickly it drains. I would unplug the machine and check the drain line for kinks or obstructions and check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the hoses or pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just something clogging a drain line, the pump, or there is a jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 15, 2009 | Kenmore 24032\24036 Top Load Washer
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Code LD
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 16, 2008 | Kenmore 22062 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
203 people viewed this question
Sal De
fordexpert
Robert Rankin
