Question about Sony VAIO VGN-UX280P Notebook
Blank Screen In the display settings, I inadvertently disabled the screen in the advanced settings. I boot up, the Windows Welcome graphics appears, etc. Then, when the desktop usually appears, confirmed with the Windows "3 note" start sound...I get nothing visually. I've tried unplugging the power cord and taking out the battery - nothing. I've tried getting into the computer in order to remove and reseat the cpu, but can't get into the dang machine. Thanks for any assistance!
  • Sony Master
  • 5,568 Answers
LOL- sorry, have done similar but it's been a while. Accidently 'removed' the keyboard. . .
Too bad you opened your notebook, most are too tempermental to open unless it is unavoidable. You removed 'the battery.' The battery pack doesn't keep settings alive, but the backup battery does and if it isn't a 'super-capacitor' it will be a 'coin' cell held in a fitting so it can be replaced without destroying anything. That cell keeps the CMOS alive and that is where your settings are stored. Normally, near that battery (or the mentioned capacitor) there will be three pins with two of them bridged currently with a jumper. If this is removed and used to bridge the center and other previously unused pin, this will kill the CMOS settings so any custom stuff you set up will go away.
You might want to try accessing the BIOS menu first though- Since everyone disagrees about which key should be used to access the BIOS, there ain't no frigging standard. Sometimes it's F1, sometimes Escape, sometimes it takes two keys. Whichever it is (you might look at Sony's website or your manual to learn which it is), you must tap several times or hold down the assigned key to open the BIOS menu.
In a section (which is also named differently depending on the position of the planets), you should find mention of 'Video' and some choices on what you want it to do. Look until you find one that involves both the internal and external video settings and turn on the VGA port accessible from the connector on the back (or side or wherever they decided to stick it). You may find the setting for the internal LCD display is turned on already so this means it's stupid Win that has let you go blind.
Someone you know still has a separate monitor sitting around and you will need to borrow it so you can turn your internal display back on.
This may not help if the external VGA port is not currently enabled as described above.
Good luck - it probably isn't the last stupid thing you'll do; I just try to keep my average to less than once a day.
Posted on Jan 10, 2009
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
My Sony Vaio VGC LA2 shows green lines at startup and after windows processing screen it goes blank. The problem started when it used to hang-up whilst the screen saver came on and the system freezes...
have you tried booting in safe mode?
as the system is booting repeatedly press F8 until a menu appears where you use the aarow keys to select safe mode by pressing enter.
Jan 24, 2011 | Sony Computers & Internet
I have a Toshiba Satillite m55-S3315 with XP Operating system and do not remember the Windows Password. Is there a way to bypass this or fix it so I can use my Laptop?
Reboot your machine. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+5009222491+3607312525+8962074949+1162261192+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2
  • Press F8 before the Windows boot screen appears. Do not press F5 as used on the NT/9x series of Windows. You will be be prompted with a boot options menu.
  • 3Select the Start Windows in Safe Mode option.
  • 4Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
    • Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
  • 5Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
  • 6The Safe Mode Welcome screen might display some of the other users on your system.
  • 7Login as the admin.
  • 8Press Yes at the prompt asking if you would like to continue using Safe Mode.
  • 9Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
  • 10Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
  • 11Login as the user for which you set the password.
  • 12If it doesn't work above, you can try to use professional support recommendation OPHCrack (freeware) to crack your windows password without erasing anything
  • Mar 13, 2010 | Computers & Internet
    Radeon X1300 card displays blank screen at logon
    Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
    Thanks for using Fixya
    Proton
    Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
    Sony VGC-LS35E BLANK SCREEN
    Do you mean after windows has booted you have a blank screen?
    Boot into windows in safe mode (by pressing F8) during the boot up process.
    When booted go into device manager and remove any video drivers under display adapters, if it asks to delete the files as well answer yes.
    Reboot into normal mode and let windows find the driver for you.
    Apr 19, 2009 | Sony Computers & Internet
    Blue scree, or system crash
    This link should help you a lot. The problem is an unmountable boot volume.
    http://www.techtips4u.com/kb/sw/SW00014.htm
    Please let me know if this helps you out.
    Mar 12, 2009 | Dell Latitude D600 Notebook
    I want to break my password
    remove the bios battery and try
    Jan 09, 2009 | Computers & Internet
    Blank Screen while Green LED is Blinking.
    It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
    Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
    Changed graphics card-then disabled the monitor by accident, now black screen.Not even safe mode works now!
    That's pretty funny (apart from the suffering)! It's doing exactly what you asked and displaying nothing to that monitor. Even if you safe-boot, the VGA thing might try to honor the setting (though it shouldn't if you have WinXP SP3.)
    Booting to a command prompt 'only' from the safe boot choices and importing some regedit settings from another machine's video might just do the trick. (As well might adding a 2nd monitor on some machine and seeing what changes in the registry using a monitor program for that.... Some 'display' key probably contains 'disabled 1' instead of 'disabled 0'.... )
    If you can get a LiveCD or bootable USB key of any sort (WinXP, Knoppix, Kevin's Rescue CD, etc.) you can probably just enjoy graphics settings by booting to that, and edit the registry or use WINCONFIG a little more freely than Safe Boot offers.
    Feb 22, 2008 | Gateway FPD2275W LCD Monitor
    Dell c640
    By default Windows XP displays the Graphic login screen with icons and usernames at startup.
    If you would like to use the more traditional Windows NT login screen you can get to that screen by pressing Ctrl Alt Del (Reboot key sequence) twice.
    If you would like to change to the traditional screen at login, instead of the graphic login screen, do the following:
    1. Log in with administrator access.
    2. Click on Start, Control Panel, and select user accounts.
    3. Click on Change the Way Users Log On or Off.
    4. Click on the Box "Use the Welcome Screen" so that there is not check mark.
    If you would like to switch from the traditional login screen to the more graphic screen just click on the box in step 4 above so the "Use the Welcome Screen" box is checked
    Cheers-Parveen
    Feb 08, 2008 | Dell Latitude C640 Notebook
    Sony VAIO VGN-UX280P Notebook Logo
    140 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
