Question about Health & Beauty
Is Panasonic shaver es 4036 used with shaving gel and foam while shaving and how to used it. Please tell me
maklean
  • 1665 Answers
SOURCE: braun shaver 8595
It must be in charge for more than three hours.Make sure that charger is working well.
Posted on Feb 18, 2008
MsCtrl
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
Blondie Girl
  • 25 Answers
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
brector3
  • 1602 Answers
SOURCE: My F-5790 doesn't shave any longer. The shaving
If the shaver heads pops up, this is because you have not cleaned it properly. This is common on this model type. You will need to thoroughly clean the top of the shaver body. Remove the cutters so that you can access it properly. You may need to use a toothpick or similar object to loosen and remove the build-up in the crevices. Then brush it all out with an old toothbrush or similar.
Clean it thoroughly and it will fix your problem
Posted on Nov 15, 2010
walesarumi
  • 6993 Answers
SOURCE: Battery in Panasonic ES8183 wet and dry shaver
A 12 months old wet and dry shaver must have a defective battery after such long period of use.
The battery cell is weak and unable to hold charge.
You sure need a battery replacement. It's not necessary you get a Panasonic battery replacement as long as its the same size, shape and watt. You can get another battery from any electronics accessories store within your vicinity.
All you need do is disassemble the shaver, remove the old battery, use it as a sample for the replacement so that you can get the same battery size, shape etc..
To disassemble the shaver, first, take the shaver outside and use a can of air to clean the shaver. Repeat this at various stages of the dis-assembly, being careful not to lose any parts!
Remove the two screws at the bottom (the end that plugs in to the charger) of the shaver, and remove the bottom cover. Keep track of the two small washers, and a small flat plastic piece, about 10mm square that fits inside of the cover - these keep the unit waterproof.
Open the shaver head, and remove the blade assembly from the white plastic vibrating arm by pulling on it - it will pop off. Undo the two screws on either side of the arm, keeping track of the two small washers under the plate - these will tend to stay in place and stick to the metal plate or the plastic underneath the plate.
Press on the mechanism from the end you first opened, and notice a gap opening up where at the other end, just below the head latch button and hinge. Gently pry open this crack, and work the case apart. Keep the large O-ring that seals the case, and make a note of its orientation so that you can assemble it the same way.
This has been too easy, I know, so there is one headache. I have not figured out how to remove the sliding trimmer assembly. Because of this, I found it was necessary to pry the large black U-shaped plastic clamp from the vibrating arm at the same time you pull the innards out of the case
By now you should have access to the battery, and proceed for the battery replacement.
I hope you understand the above.
Good luck.
Posted on Mar 01, 2011
What is the best beard trimmer for styling and sensitive skin?
Yes, you are right! Now a days most of the people are using electric shaver because of its advantages like:
  1. It gives a fast shave.
  2. It is cheaper than manual shaving kits
  3. It gives a smooth shave and also there is no chance to get cut or skin irritation
If you are looking for beard trimmer than i will let know that trimmers are used to cleaning up the edges. I would recommend you to use clippers rather than using trimmers because clippers are used for doing the bulk of a haircut.
Aug 16, 2014 | Panasonic ES 8077S Electric Shaver
Any tips for shaving my bikini line? Should I use a special gel or shaving foam?
Actually, what you lather on to your skin before you use the razor will make a big difference. Don't use regular soap.
Using a proper shaving foam can help moisturize your skin, give a smoother shave and help to prevent ingrowing hairs. It's worth spending the money on a proper product.
Feb 14, 2013 | Health & Beauty
Shaving with an electrical shaver is considered to bet wet or dry shaving?
Most electric shavers are dry, meaning that you don't need any gel or a shaving cream in order to shave although there are some unique wet electric shavers' models on the market.
Feb 06, 2013 | Health & Beauty
Scratching and slight pain
Possible issues: 1. Shaver not charged 2. Shaver not powerful enough 3. Shaver's blades dulled
Try using electric shaving gels/ointments like Lectric Shave or something like that.
Jun 07, 2011 | Health & Beauty
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Dec 15, 2010 | Panasonic Sonic-2 ES 4011 K Electric...
Where can i get replacement batteries for a Panasonic ES7103. i only get about 3 shaves then it needs a recharge. Thanks
Panasonic does not allow the sale of their specialized shaver batteries to consumers. For additional information, try calling Panasonic at 1-800-338-0552
Dec 02, 2010 | Panasonic ES 8077S Electric Shaver
Using a Model1180X Senso Touch. I would like to use it wet shaving with shaving cream, which shaving cream will get the best results and not damage the unit? (Norelco 1180X) ?
Sensotouch shavers can be used with any shaving gel or cream. It will not harm the shaver. Philips makes no recommendation as to which type is best. Just use whatever favorite brand that you have
Oct 08, 2010 | Norelco Health & Beauty
Do i need to apply shaving gel/cream?
applying shaving cream or gel is optional. It is not neccessary but you may prefer to use it.
Jun 06, 2010 | Norelco Arcitec Electric Shaver -...
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
