Question about D-Link DI-704P Router
Problem on connecting the internet
I use D-Link DI-704P Router on my network. I connected it to my hub to share the internet connection to my client and i use it as my dhcp server. The connection work fine but my problem is from time to time the internet connection drops. I need to release the ip address then renew it before the connection will work again. I don't know if the problem is with the router or my hub. Any solution is very much appreciated.
  • Mark Vispo Jun 06, 2007
    Thank you for your reply. I need to connect it to a hub because i have more than 10 clients that needs internet connection.
Do all the clients lose their connection? My first suspect would be the ISP, then the modem.
Posted on Jun 06, 2007
  • 196 Answers
Why are you using a hub? With a router, you can connect direct to the client. Eliminate the hub and see if that helps. Be sure to follow all the manufacturer's instructions for setup.
Guide on how to use the DI-704P router to connect to other computer
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 13, 2011 | D-Link DI-704P Router
D-Link DI-704P as wireless
Yes, you have to. The router model mentioned is not a wireless router, not unless you have other network device there that transmits wireless connection such as a wireless access point.
Jul 05, 2009 | D-Link DI-704P Router
''Network Cable Unplugged'' problem on Linksys but not on D-Link
Most likely the connection inside your new gateway is bad - you should return it under warranty & get a new one.
Apr 13, 2009 | Computers & Internet
Problem D-Link DI-704P
then configuration problem then re-configure it check ip addresss, dns value, firewall, proxy server any antivirus is on then off it. some they also create a problem
Mar 09, 2009 | D-Link DI-704P Router
Slow internet connection
Go to http://www.dslreports.com/speedtest to see how fast your internet speeds really are. Then contact your ISP to see if the speed you are getting is within tolerance for the package you pay for.
Jul 11, 2008 | D-Link DI-704P Router
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
My router is failing
I have had many D-Link routers fail ova the years and they all seem to start off just as ya describe , then go toes up... after a bit. Of course B4 getting another unit, one must first re-install all drivers, check all cords, cables etc. just to rule out anything else. Then get a nice new modern one :)
Aug 15, 2007 | D-Link DI-704P Router
DI-704P unit power problem?
Unplugging the router resets it, I don't realy think its a power problem. The power pack contains a transformer that steps down (reduces) the power from 115V down to the 12V (or so, I don't really recall any more) the router uses. The byproduct is heat which can range from warm to uncomfortable to the touch. It?s not uncommon to have to reset your router and/or cable modem on some basis. At one time I had a DI-704 and had to reset it on a weekly basis to reestablish my Internet connection. At the time I thought it was my router but later it turned out to be a problem with my access provider supplied modem. How often are you having to power down the router? Who provides your access?
Feb 06, 2007 | D-Link DI-704P Router
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
D-Link DI-704P Router Logo
98 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
