Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keyless pad and remotes not working but pad inside garage does
The remotes are making the green light flash when I press on them but they will not open or close the door. I read on the instructions on the main box that to press the Smart button for 6 seconds to reset the remotes, but that did not work. Any suggestions?
  • Anonymous Feb 02, 2009
    Mine is a Chamberlain 1/2HP, indoor pushbuttong flashing but still work, remote does not work.
    Some web site suggest the controller board is gone?
    Help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Be sure the remotes you have work with the operator you have. Check to be sure your batteries are good. Press and release (do not hold) the "Smart button). Press and hold the button on your remote about 2 seconds. If that does not work your remotes are bad or the reciever could be bad.
Posted on Jan 11, 2009
Our keyless entry pad flashes when we enter the code and press 0 to open the garage door. It used to work fine. Garage door does open with wall switch inside.
On this model of keypad, you should be pressing "Enter" to open the door. Find the "Learn" button on your opener (usually on the back, or under the rear or side light cover, a red square button), press it, then go to your keypad, enter your 4-digit code, and press enter. The opener lights should flash. If this doesn't work, there may be another issue, for which you will likely need to contact a repair service.
Sep 16, 2013 | Sears Craftsman LiftMaster Chamberlain...
Door does not open or close when using the remote. It closes only when pressing the hard wired square white touch pad. Behind the opaque white touch pad, one can see a flashing/blinking green light.
Using a step stool, reach up and remove the covers (the white covers pop off). The instructions will be labeled on the back plate for setting your remote control's security code Make sure the remote has a battery installed and is compatible with your garage door opener. Or go to the LiftMaster web site and down load its operators manual.
Jul 27, 2011 | liftmaster Garage Door 1/2 Hp
How do you reset your code on the outside touch pad for garage door when you dont no the 4 digit code from previous owner
Get all the remotes together.
On the end of the GDO (where the wires are) is a "Smart" button.
Press and hold the smart button for 10 seconds (until the LED goes off). This will clear the memory.
Now press and release the smart button, take one of the remotes and press one of the buttons (usually the top, largest one). The light should flash on & off.
Perform this same procedure for all other remotes. Also do the same with the keyless entry. Always press the buttons slowly on the keyless entry. It is easy to mispress a button.
Jan 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage opener and my lock won't work
The wireless keypad should work but the remotes should not. I suspect a bad wall control but there is a possibility of a bad logic board. If you have a neighbor with a 3 button wall control see if they will let you borrow it to eliminate that problem. Just make sure you note which wire goes where on the back of the control. They are color coded.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
140 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
