Question about Konica Minolta PagePro 1390MF All-In-One Laser Printer
Konica minolta page pro 1390 change drum
After we replaced new original drum its still showing error change drum?
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Posted on Aug 23, 2009
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Posted on Oct 15, 2009
  • 41 Answers
SOURCE: Need Win 7 driver for Konica Minolta Page Pro
Good news they are making the driver for it...
Bad news they expect it in July of 2010
Here see for yourself
http://kmbs.konicaminolta.us/content/support/windows7.html
My scanner a visioneer 6200 was not compatible with windows 7 They said I needed a newer version. I used the oldest scanners drivers that I could find for windows 7. ended up using something like e the Visoneer
8200 for my 6200. It still works excellent to this day.
I would try a driver they made for windows 7 for their oldest Konica Minolta Page Pro that you can find. See if it works good enough until 2010. Let me know please
Posted on Nov 09, 2009
  • 10406 Answers
SOURCE: Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Posted on Apr 07, 2010
How do I rest a drum on konica minolta C554e
Then the drum you replace is not new there is a chip on it which tell the copier its new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 27, 2018 | Konica Minolta Office Equipment & Supplies
Konica minolta pagepro 1500w drum error
The Pagepro 1500 is an older design and the drums on those are only rated for around 12,000 pages or so. Unless you have a computer that can query the printer directly to get the error code the print driver is giving I can only recommend disconnecting power, remove toner, remove and replace drum, replace toner and reconnect power. (Cold reset) But, if the drum has reached its end-of-life then the only option is to replace the drum. At that point it's better just to buy a new printer; the drum replacement cost will probably be prohibitive.
Oct 26, 2016 | Konica Minolta Office Equipment & Supplies
How to replace Konica Minolta Page pro 1580 mf toner. please tell us
is the toner 3rd party or OEM. Replace with OEM cartridge. Well the toner is not the drum you bought a drum it needs toner. ????
go this site for operator manual
Self Help Product Support Konica Minolta Business Solutions Inc
Dec 18, 2015 | Konica Minolta Office Equipment & Supplies
The error show replace drum unit and developer but when i replace it with new drum unit and developer the error still shows drum unit and developer need to change?
you did not do it right first you run drum dry, then clear the counter then install the new drum and developer, now get new developer and drum and follow the service manual drum dry first then clear counters then run TCR adj. then run gradation procedure Better to get a tech to do it.
Aug 13, 2015 | Konica Minolta Bizhub 423 Copier Printer...
How we reset printer konica minolta 1390
About 88,000 results (0.73 seconds) Search Results
    [PDF]PagePro1380/1390 MF Service Manual - Printers - Konica ...
    printer.konicaminolta.net/drivers/other/1390/1380_90_fs.pdf
    the risk of damage to the product, KONICA MINOLTA BUSINESS TECHNOLOGIES, INC. (hereafter called the KMBT) strongly recommends that all servicing be ...Missing: we
    [PDF]PagePro 1390 MF Printer / Copier / Scanner User's Guide
    images10.newegg.com/User-Manual/User_Manual_28-117-006.pdf
    PagePro is a trademark or registered trademark of KONICA MINOLTA. PRINTING .... Print Media 20. What Sizes of Media Can I Use? 20 .... Stop/Reset key. Exits the menu. ... Right-click the KONICA MINOLTA PagePro 1390 MF printer icon.
    [PDF]Technical Guide - Printers - Konica Minolta
Feb 12, 2014 | Konica Minolta PagePro 1380 MF Laser...
Konica minolta bizhub pro c500 error code sc29-19
check, the drums, no scratches, if good the surface of the drum, interchanges the drum, for example, move the drum cyan to the drum yellow.
Jun 07, 2012 | Konica Minolta Bizhub Pro C500
I have a SCANNER ERROR lamp error message on my Konica Minolta 1380mf page pro pinter, do you know how I can fix it please?
You have a bad drum unit, you will need to replace your drum (dr310) along with the developer (dr310) it's not all that difficult but requires several step to reset the error code, clear the counters and calibrate.
Sep 19, 2011 | Konica Minolta PagePro 1380 MF Laser...
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica Minolta PagePro 1390MF All-In-One Laser Printer Logo
184 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
