Question about Black & Decker 15.6 Volt DustBuster Vacuum
How do I clean filter on black&decker DustBuster pivot 18v
    New Friend:
  • 3 Answers
(The below worked with my 9.6v version - I assume the others in the pivot range will be similar).
If you open the lid (where the dust collects) you can twist the inner plastic filter about 30 degrees to unlock it. Then, with a bit of "fiddling" with the fold out part (press the unlock button and rotate the suction part as if you were going to use the unit) then, the plastic internal part and the whole suction bit will come off the motor part. Do this slowly as the inner filter will be full of dust and muck. You can then take the filter out, tap it clean in the bin and then wash and dry it with washing up liquid (gently) and allow to fully dry before putting it all back together again.
Posted on Jan 20, 2013
joeguest2
  • 2080 Answers
SOURCE: I have lost the manual
First of all, here is the main Black And Decker ONLINE SUPPORT page for your model:
http://servicenet.blackanddecker.com/Products/Detail/CHV1408
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
To download a copy of the OWNER'S MANUAL for that model, just look under the DOWNLOADS heading when you get to the support page and click on the red and white icon beside INSTRUCTION MANUAL (Print Doc).
After you click on that icon, it will ask you if you want to open or save the file.
Choose SAVE.
Now Choose a location on your computer where you would like to save the file.
The easiest place is just right on your DESKTOP so it will be easy to find later.
Then click SAVE.
Once the download completes in about 5 seconds,
Click on the OPEN button.
If the document opens then just read it, or print it off if you want, or just leave it on your computer to reference when you need it later.
If the document does not open, then you may need a PDF viewer program like ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there and then follow the onscreen instructions to install it.
Install the ADOBE READER program then you can come back to your desktop and open the USER'S MANUAL document and view it without a problem.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Posted on Apr 19, 2011
SOURCE: Black & Decker hand held dustbuster
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
Posted on Dec 06, 2007
ukvacfan
  • 328 Answers
SOURCE: Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Posted on Mar 07, 2009
Richie_asg1
  • 1036 Answers
SOURCE: how do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Posted on Dec 26, 2008
  • 10 Answers
SOURCE: no problem - received a Black and Decker pivot and need to regist
Simply go to www.blackanddecker.com and register to register your Black and Decker product.
Posted on Apr 16, 2009
Can I fix model cwv363004 black &decker
Hi-
This dustbuster does not have internal parts still available to replace. This model currently still has the filter, wet deflector and crevice tool available. If you would like to locate a service center for further information you can follow the link to find your nearest service center. blackanddecker com
Thanks
Black + Decker Customer Care
Feb 21, 2015 | Black & Decker 15.6 Volt DustBuster Vacuum
Black decker dustbuster pivot is not recharging
Black and Decker Auto Pivot Vac #PAV1200W is only for vehicles as this operates off your battery via cig lighter. You have to remove the cig lighter. Also, it will not use A/C outlet even if you have cig socket version in A/C outlet. Did not even vac or have power. I thought that I could use it for inside house and in cars, but it's only for cars. Haven't tried it in my car yet. Thought this would of been good for deep down in couches and stairs, but I guess not. Just saying. It's now off the market I see.
Apr 11, 2012 | Vacuums
Black and Decker 14.4 Dustbuster, how do I wash filter?
Here you go - this will take you to your instruction manual. It looks like you just wash it with soap & water and let it air dry.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90513719,chv9608%20etc.pdf
Jul 08, 2011 | Black & Decker Vacuums
What is the "wheel" on the side of the dustbuster for? what position should it be in?
The wheel is the pivot and cover for the filters. It opens up to show the filters behind for cleaning.
Mar 11, 2010 | Black & Decker AV1200 DustBuster Handheld...
How do I clean the filter? can it or any part of
The fliter can be tapped aginst a garbage can to release soil. Using compressed air outside to blow off remaining soil and dust. The manufacturer will have replacement filters available.
Oct 10, 2009 | Black & Decker 15.6 Volt DustBuster Vacuum
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
How do I open the dustbuster to clean out the end
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Black & Decker 15.6 Volt DustBuster Vacuum Logo
5,028 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
