Picture but no volume
52 in.rca have a picture but no volume
  • albertstoneo Jan 11, 2009
    thanks but no thanks we already fixed it.didn't need a new one!!!!!!!!!
So what is the solution???? but a new one???
Posted on Jan 11, 2009
  • munah24 Jan 11, 2009
    so what is the solution???? buy a new TV??????
    so if you had picture and no sound and fixed the problem why not share it with the rest of us or is thet forbidden???????
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Go to menu then got to picture then go to advanced picture settings and turn off the auto format button
Nov 07, 2011 | RCA D52W23 52" HDTV CRT TV
I have an 52 inch hdtv model number hd52w59 and my tv was workin fine and then it started to make this popping noise in the back and now sometimes my menu screen pops up the volume changes and it changes...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W58 Picture not working / Sparking in back.
maybe there is a lizard inside, open the back cover then remove the PCB. re solder the damaged area and clean it with an electronic spray cleaner. check for cold solder component leads and re solder it.
Jun 11, 2009 | RCA HD52W58 52" TV
Rca 52" rear projection tv (P52926) volume control LOCKED!!!
This can be a tricky one, I would check the 5 and 3.4 volt lines first with a DVM (analog meter will not due) then with a scope to see what the voltages are and what they look like. A bad cap on the rail for the e-prom can cause this or the eeprom may be bad, this also happens. It might be best to contact a scv. co. as you can a lot more problems in that area if your not familiar with it.
Feb 26, 2009 | RCA P52926 52" Rear Projection Television
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
My rca tv
You should be able to do all of the above IF hook up correctly
May 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
did you go in to you menu and set you audio setting.
Feb 15, 2008 | RCA 32F531T 32" TV
Televison & Video Logo
Top Televison & Video Experts
