Question about Yamaha RX-V630 Receiver
Immediate shut I have a Yamaha Receiver RX-630. It's 3 years old and had been working fine all thru these years. Just recently i saw a message on its deplay about " SP wires" and it immediately shut down after that. Now i am not been able to power it on. On pressing the power button, I hear the relay clicking sounds, which feels like shuts receiver off immediately due to some power circuitary mechanism. Any idea what's going on and suggestion how to receover fromt his. BTW - i have disconnected all speaker cables from the receiver but still seeing the same immediate shut down problem occuring. Any idea on how to further isolate the issue.
  • pufalumpagus Nov 12, 2007
    My reciever will do the same thing, but it will come back on. The funny thing is that during the summer we have absolutly no problems at all. Then when it starts to get cool out the reciver will go through bad days where it will shut down constantly. Then it will be good for a long time. I have also unhooked wires and it has done the same thing. It also does not matter what volume it is at. Very frustrating.
  • Anonymous Jan 23, 2009
    my RX-V630 shut down after flashing up the 'check sp wires' message on the panel. it now point blank refuses to turn on, emitting only a brief click (and a whiff of burning on one occasion). Plug and circuit board fuses are intact. There is no visible scorching of the circuit board. I do not wish to electrocute myself so I have replaced cover and will leave unplugged for a couple of days before attempting to power on again without speakers attached. From reading other comments online it could be a fried transistor caused by a faulty speaker connection that was not caught in time by the circuit board. I anticipate having to drop £150-£200 on a replacement.
    President:
  • 3,130 Answers
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Posted on Jun 06, 2007
2 Suggested Answers
SOURCE:
dsom
  • 56 Answers
SOURCE: Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Posted on Jun 07, 2007
All digital inputs dead
Main control board fault. Contact the authorized service center. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 30, 2015 | Yamaha RX-V2500 Receiver
I Have an Yamaha RX-V1300. Is there anything I can to allow it to pass thru 3D video signal?
No. You'll have to connect the video to your TV and then pass the audio to the receiver. 3-D pass-thru was only added to some audio receivers with HDMI outputs in about 2010. The Yamaha RX-V1300 was released at least 7 years earlier. Video monitors/TVs with 3D display were virtually unknown when this model was released. You can find the specifications for this receiver here: http://usa.yamaha.com/products/audio-visual/hifi-components/stereo-receivers/rx-v1300_black__u/ (click on the Specs tab).
I wish that I had better news for you.
Dec 01, 2014 | Yamaha RX-V1900 Receiver
How do I reset a yamaha rx-v493 receiver?
Disconnect any speakers from it and see if it still turns off. If it doesn't, then you have a shorted speaker or speaker wire. If it does still turn off, then it would need to go in for repairs.
Jan 09, 2013 | Yamaha RX-V493 Receiver
Amp keeps shutting off
• Check again with no speakers connected, if it doesnt shut off,
Check speaker system, connect one at a time to find the cause.
• If the receiver still shuts down without the speakers,
troubleshoot inside the unit.
Aug 04, 2012 | Yamaha Rx-a710 Aventage 7.1 Home Theater...
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
Power shuts off
is it pl;uged direct in wall must nbe on a nice hi end break surge proably got zapped transisters in it best to try to replace it u can try to un plug it from that outlet few min then back in anther one
Jan 21, 2008 | Yamaha RX-V890 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V630 Receiver Logo
701 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
