Xerox wc 5020 error cod U2
Error cod u2
checkitright
  • 1362 Answers
SOURCE: xerox U2-2 erroe code
You did not say what type of copier this is, but most codes are the same for most of the copiers.
Look at this link:
http://www.copier-help.com/copier-help/ecs/xerox/ecx1012.html
Posted on Oct 26, 2007
sir fixalot
  • 146 Answers
SOURCE: Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Posted on Nov 11, 2008
SOURCE: Error code U2-40
u2-40
Posted on Sep 10, 2008
  • 24 Answers
SOURCE: u2-40
try a reset with sim 16 first, it just may go away
Posted on Sep 12, 2008
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
XEROX WorkCentre 5020 given error code u2
That error signifies a carriage fault with the ccd scanner under the platen glass. Check connections of flexible cable and verify that the carriage moves left to right upon start up. If connections are okay you either have a defective IIT Carriage or IIT Carriage Sensor.
Apr 27, 2016 | Xerox Office Equipment & Supplies
U2 code for xerox work center 5020
U2-1 Carriage Module Fail
Maybe you can find more information in the service manual. About error codes go to page 20
Apr 16, 2014 | Xerox Office Equipment & Supplies
Problema con mi impresora codigo u2
Codigo de estado U2 / Sub Codigo 01 AVERIA DE LA MEMORIA
La PWB principal detectó una avería de la memoria
Codigo de estado U2 / Sub Codigo 02 AVERIA DE LA MEMORIA
La PWB (Placa de circuito impresa) principal detectó un error de acceso
Procedimiento para ambos casos
Realice el procedimiento de anulacion del codigo de estado U2:
  • Introduzca el código de diagnóstico 16.
  • Pulse Impresión.
Si todavia existe el problema , substituya la PWB principal.
Aug 20, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
My sharp a163 xerox machine is give a u2 40 error code how can i solve it
U2 -40 cause when the toner cartridge crum data read error
Execute SIM 16 and checke you install a specified toner cartridge
Dec 24, 2010 | Sharp AR 163 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Xerox 5314 copier giving error code of u2
A U2 means the machine did not see the lamp scan. The lamp did not leave the right side of the machine. May be hung up on something, may have broken a cable the scan motor may be bad, I would first of all remove the glass and see if there is anything binding the lamp and keeping it from scanning. If you think it feels tight to move, that is normal on a 5314. What I am looking for is the lamp stopping not being able to move.
Mar 14, 2009 | Xerox Office Equipment & Supplies
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
3,422 people viewed this question
k24674
jasbo
jasbo
