Question about Boating
Fuel mix for a mercury xr 10 outboard - Boating
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Posted on Jan 05, 2009
dunglizard
  • 3 Answers
SOURCE: Fuel mix ratio for 115 hp force outboard engine
50:1 ratio
Posted on May 23, 2009
  • 10 Answers
SOURCE: fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Posted on Oct 25, 2009
Testimonial: "Thank you coachtheune. I appreciate your help."
  • 53 Answers
SOURCE: My outboard mercury has been sitting several years
your engine is fuel injected the fuel system is clogged with bad gas. fuel is proven to only stay stable for 60 days. after that it begins to turn to varnish. I can lead you through the repair easily, but i do suggest you go to this website to get picture diagrams so you can see how the engine parts are lined up. www.mercruiserparts.com. upper right had corner of page click search with pictures. select product line. select column Mercury, force, mariner and other outboard select mercury mariner scroll down to V-150XR1 next page. verifiy the serial number then click on it. ok now you have a list of picture, discription and part numbers to view. TOOLS (1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a outboard owner you will always need them. TROUBLESHOOTING (1) check compression. I'm giving you a average numbers. Look at your Clymer manual for more specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs. If you have good compression (2) check spark. use a spark gap tester, all cylinders should jump a half inch gap.replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive.(3) Replace all fuel filters. there may be one on the boat. there is a fuel filter under engine cover on the starbord side replace it. Test drive boat. I know it is time consuming but I am making sure you don't spend time and money when you dont need to. If problem is still there (4) the fuel filter you replaced under the engine cover follow the fuel line to the vapor seperator.(website fuel managment system breakdown reference numbers 21-25) (5)on the bottom of the seperator is a hose leading from the fuel seperator to the electric fuel pump. NOTE, what i want you to do is verify fuel is getting to the vapor seperator and to the electric fuel pump. because there is a needle and seat in the vapor seperator and a filter in the hose that stops up. NOTE the filter in the hose (reference number 48 on website)make sure you remove hose completely and check by blowing threw it(6)with hose removed use primmer bulb and force fuel into the engine. fuel should pour through fitting that the hose was connected to. If not we have more work to do. I'm hoping you filter is stopped up in the hose. IF THERE IS FUEL FLOW AND FILTER STOPPED UP put everything back together with new filter and test. if no improvement you have pressure test to follow in you clymer manuel. follow each step about fuel pressure test. you are testing the electric fuel pump a $600.00 unit. IF NO FUEL FLOW FROM FITTING and hose filter replaced( why put the old one back?) (7) You fuel vapor seperator needle and seat is stopped up. refer to websit pictures. reference numbers 23 and 24.(8) there is six screws to remove the top of the seperator. a o-ring that can be saved but i would suggest ordering a new one.WARNING float level is setting is critical be careful not to bend float or rod(9) Remove float and needle and clean seat thoughly with carb cleaner. use primer bulb and pump fuel. Does fuel flow? if yes replace needle and float and use primer bulb again. gently close needle by pushing on the float. you should be able to stop and start the fuel flow with the float and needle. if you have any worries order new parts.(10) after you have verified fuel flows and stops through needle and seat. look inside of seperator housing is there any sedement or varnish. IF CLEAN reasemble vapor seperator. IF DIRTY the vapor seperator also receive oil from oil pump at the bottom of the seperator look for hose and fitting. make sure oil fitting is clean if ANY DOUGHT ABOUT OIL DELIVERY REPLACE VAPOR SEPERATOR YOU CANNOT GET THE OIL VALVE SEPERATE IT COMES IN A KIT. ok I have taken you through the basics everything else is in the Clymer manual you need to purchase. good luck
Posted on Nov 03, 2009
  • 677 Answers
SOURCE: fuel ratio for 1968 mercury 9.8 outboard
The fuel ratio is 50/1. Eg.50 gallons of fuel to 1 gallon of oil.
On an older motor and newer cleaner burning oils,you may bring that down to 45/1.Hope this helps
Posted on May 29, 2010
2002 mercury 125 outboard will not run on all 4 cylinders
fuel injected model , have the fault codes read
carby models have the entire fuel system cleaned out and all rubber hoses, pump diaphragm replaced as the hoses break down internally and put rubbish in the pump and carby's
do not use e-mix fuels as the ethanol absorbs moisture and that corrodes aluminium bits , rusts fuel tanks and breaks down the rubber components
Jun 13, 2017 | Mercury Boating
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
1996 mercury 60 horse 3 cylinder 2 stroke
problem in the idle settings of the carby
could be rubber bits from deteriorating rubber hoses /water in the circuits but it needs attention from accredited mercury service centers
Apr 25, 2017 | Mercury Boating
Need a free manual for 1966 Mercury 3.9 hp outboard motor.
Don't use WD40, it is paraffin AKA coal oil
Sep 10, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
What is the fuel mixture for a 9.9 mercury outboard motor?
With modern oils all 2 cycle engines (if it is a 2 cycle) can be safely mixed at 50:1. Most auto parts stores will carry the proper 2 cycle oil for outboard engines.
Jul 07, 2014 | Cars & Trucks
Fuel oil mixture for 1986 mercury 115
Oct 25, 2009 | Boating
Mercury 200 blackmax oil to fuel mix
Fuel oil ratios are,50/1. Eg.50 litres of fuel and 1 litre of oil. Hope this helps
Aug 29, 2009 | Furuno Navpilot 500 Designed for Use with...
Smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Aug 23, 2009 | Sport & Outdoor - Others
Boating Logo
138 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
