Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer not freezing
Over night the left side (freezer section) starting thawing with all the ice having melted. Temperature is around 40 - 50 degrees in freezer. Door is closed properly, and freezer is now empty, but water left in a glass over an hour has not frozen.
Bothe freezer and refrigerator were set on 7. I have moved it up to 9 in an attempt to see if it freezes again.
    Problem Solver:
  • 9 Answers
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Posted on Jan 10, 2009
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
At first we though the freezer or refrigerator door had been left open. Ice was melting and dripping in freezer, food was thawed out, but the temperature in the freezer still indicated it was zero +/- 2...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 14, 2009 | GE PSC25NGS Side by Side Refrigerator
I have a Kenmore Elite side by side refrigerator/freezer and just had the ice dispenser motor replaced a month ago when we first moved in our new house. However, our daughter left the freezer door ajar...
It would not hurt the motor as they are built to be exposed to some degree of moisture if the defrost does not work i would check and see if something is jamming the actual mech. up. In my ice dispenser i had stuff fall in from the shelf's and seized up the motor. Any how if the thaw does not work check out a motor at repairclinic.com (http://www.repairclinic.com/SSPartDetail.aspx?s=t-106.53769202-%3d%3dc203i1057785&PartID=1057785)
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer temperature dropping/digital display reading zero +/- 2
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Mar 29, 2009 | GE PSC25NGS Side by Side Refrigerator
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Help, no water but have ice out of door on amana side by side.
The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
292 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
