Question about Hoover Washing Machines
Door lock jammed on hoover 1300 special edition front loader,sounds that the electric lock operates but handle will not pull out,is it a case of breaking latch assy off?
SOURCE: Hoover performa 1300 door latch
my hover performa 1100 door latch will not open can anyone help
Posted on Sep 16, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Posted on Jan 04, 2009
  • 1294 Answers
SOURCE: Pulled the handle to early to open the 7kg front
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Try these sites for spares:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 02, 2009
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Door wont open and F34 error message on our axxis front loader
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
Sep 27, 2008 | Bosch Washing Machines
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Front passenger door will not open 1998 Tercel
If the passenger door has not been opened for some weeks or months, or in icy weather, it is possible that the rubber seals around the door frame will cause the door to appear 'stuck' fast - in this case, a bit of extra force from inside the car whilst pulling on the interior door handle should cause the door to open. Failing that, if the car has electrically operated central locking, when the key fob is pressed to deactivate the central locking does the door lock on the passenger side work as expected? Try unlocking the passenger door with a key, and or pull the door lock button upwards to ensure that the lock has been deactivated. Check for blown fuses.
Oct 06, 2009 | 1998 Toyota Tercel
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
Hoover Washing M/C Door Jammed
we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
Nov 03, 2008 | Hoover AAA160 Front Load Washer
My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Jul 29, 2006 | LG WD-1080FD Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
