Signal quality I get 100% signal strength but 0 to 8 % signal quality on most of the local channels and the signal quality will float up and down. I have a high gain DTV antenna and a mast mount amplifier. I have about 20 ft.run to one TV and fifty ft.to the other with amplifiers at both sets. I have a metal roof but the antenna is mounted on standoffs so it does not sit directly over the roof. I am about 30 miles from the transmitter in mountainous terrain. Can you please tell me what is effecting my signal quality, and how can I improve it?
  • Hayward Cowan Jan 12, 2009
    That sounds reasonable, but will involve a considerable expense errecting a tower, ect.
    If you are certain that will resolve the issue then I will do it.
    How high above ground level should I place the antenna
    President:
  • 1,990 Answers
Welcome to Fixya! Question---Are you using the New Converter Boxes that Everyone will need next Month? Let me know so we can go Further!
Posted on Jan 12, 2009
  • 356 Answers
Atmospheric conditions will affect signal quality, sounds like you have the best setup for the area, to improve the signal quality you will need to face the antenna towards the signal source, I have provided a link that will help you detirmine the optimal direction your antenna should face.http://www.antennaweb.org/aw/welcome.aspx Let me know if this helps, I can assist further. lone99star
    Top Expert:
  • Televison & ... Master
  • 64,034 Answers
The signal is being affected by the terrain of your area, the signal bounces off the hill and mountains and changes strength as it does, there is no way to escape this except to move the antenna to higher ground and run a cable to it with a hi gain amplifier at the end.
Satellite signal strength is good 56% but the quality is 0% how can correct this problem
Please try to increase the satellite signal to make this channel works.
Feb 02, 2011 | Televison & Video
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Dish Vip211K receiver locks up on one channel
yes your signal is very good but it hangs up, the most important is the quality of your picture, cause signal is composed of so many impurities including noise, so dish be orientated once more.thanks.
Mar 27, 2009 | DISH Network ViP 211 DTV Receiver
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Digital television signals
What type of digital tv signal? Satellite or OTA (Local Digital Antenna Channels)?
What type of equipment is the split signal going to? Straight to the tv's or some sort of Satellite or HDTV Tuner box?
Dec 19, 2007 | Motorola HDT101 DTV Receiver
Off-air antenna volume issues
Make sure you have the correct audio settings set on the HR10. Go to messages and setup, settings, audio and play with the different settings and see if you can't get any audio to come on.
If you are able to get a dolby 5.1 audio signal through your receiver on another hd channel, then you should be getting and audio signal on your locals.
If you aren't able to get any dd 5.1 audio on hd channels, then I'd suggest (if you can) bypass the receiver and go directly to your tv (if it has speakers).
Dec 06, 2007 | Directv HR10-250 DTV Receiver
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
